2WD or 4WD |
Post Reply | Page 123> |
Author | |||
bobbarker733
Newbie Joined: September-28-2012 Location: Charlotte NC Status: Offline Points: 22 |
Posted: March-09-2013 at 1:20pm |
hey guys
I'm considering upgrading my tow vehicle for a Toyota 4Runner and I'm trying to figure out if I want 4WD. I got a 86SN and the 2 ramps I use are concrete slabs. It's pretty flat between my house and the ramp locations and I don't plan on driving further than that. Also I don't need 4WD for anything else (winter, off roading). So my question to you is: do you use 4x4 when pulling your boat out of the water? I know angle vary, surface texture, some got slippery stuff on them.. Maybe I should rephrase my question to: have you ever had problems pulling your boat out, on RWD, and using concrete ramps? Let's see :) |
86 SN and lovin' it!
phatsat67
Grand Poobah Joined: March-13-2006 Location: Indiana Status: Offline Points: 6149 |
I've had a varity of 2wd trucks. Never been stranded at any ramp yet. Our ski club ramp has a slab but while the boat is still on the slab the truck is in pea gravel.
I always am amazed with people doing burnouts on boat ramps trying to pull things out.On ramps wet or dry I never had a problem even with my smallest truck the Dakota. It had 10 inch wide summer performance tires most of the time. 86 Ski Nautique as well but pulled various other boats. Clearly the best of all the 2wds was my diesel purely because of weight and low end torque/manual transmission required no throttle input to pull boats out. My new 1500 will actuall slip a tire just a hair more than the little Dakota. The only vehicle I owned I used 4x4 to pull out of ramps was my 04 Dakota Quad cab. It was a stick with a low gear ratio rear end so it took some throttle to move a boat and it was an open rear end so it would spin easily. 4x4 button and problem solved. Don't blow the extra cash on 4x4 if it is not needed. Our river ramp is probably one of the steepest around and I've pulled out much heavier boats there than my 86. 96 2500 diesel dodge 2wd 99 R/T dakota 2wd 2010 Ram 1500 2wd |
OldSchoolBlue84
I would agree with Zack but it is nice having it. Use to pull with a 93 2w Ford Explore 2 door and a few times I was quenching my rear end. If you eliminate the spinning, should be good to go. Now I pull with Jeep Commandor AWD V8 and its a dream.
Kostas
1984 Ski Nautique 2001 |
SNobsessed
If you are at a slippery ramp & have someone with you when you pull out, have them sit in the bed, the extra weight over the wheels makes a difference.
ononewheel
Gold Member Joined: June-21-2011 Location: B Status: Offline Points: 776 |
While in Wisconsin I had a F-150 4x4 that would not pull the boat out in 2wd. No matter how easy I worked the throttle and clutch. They were concrete ramps too.
I'd bet it depends more on the condition of your ramps and how busy the boat/ wave action is in your area. Around Madison, the waves pushed alot of weeds and slime onto the ramp, and often the lowering of the lake left a muck on the ramp. The ramp was always busy too leaving it wet and slippery. If you find the right deal on a 2wd, pull the trigger in my opinion. They are slightly less on maintainence, and the traction problem could be solved with a little weight like others have said, or a little push from the boat. |
If we let the professionals do everything it takes all the fun out of youtube
Smithfamily
Platinum Member Joined: December-26-2007 Location: Orlando, Fl Status: Offline Points: 1602 |
I pull my 92 SN with a Suburban 4WD. I have never engaged the 4wd, for any reason with the boat, ramps, or drive. I like to have the option, but realisticly not needed. If the opportunity presents itself, I could pull a house down with it!!
Js
OverMyHead
Grand Poobah Joined: March-14-2008 Location: MN Status: Offline Points: 4861 |
I also had a v6 Dakota with a clutch. I liked to use 4 low at the ramp. Mostly because I believe it is good to engage it now and then and also it is a lot easier on the clutch. No gas, just let the clutch all the way out and creep to dry flat ground. 4wd definitely inspires confidence, but if I did not live in a snowy climate I am not sure if I would bother. If you have full time rear wheel drive I would not expect problems in most normal conditions. Front wheel drive is a different issue.
1987 Ski Nautique |
Hollywood
Maybe its just my ramps boats and tow vehicles but I've never needed it. 4wd wasn't always so available, plenty of boats have been pulled out the old fashioned way.
And some people can't live without their GPS either... |
Foot_Fungus
Gold Member Joined: February-27-2012 Location: Chapin, SC Status: Offline Points: 501 |
4wd is one of those things that you will kick yourself for one late night when you pull your boat out on a shady lookin ramp and start slippin. I very rarely use my 4wd, but there have been a few times when I've been glad I had it. Of course a good lsd rear end will also do wonders.
'94SN Restoration underway...
harddock
Platinum Member Joined: June-04-2008 Location: Toontown, MA Status: Offline Points: 1763 |
in the good old days, the boats were heavy, the ramps were nothing special and most people towed with a station wagon or a convertable. Now everyone needs an AWD or a 4x4. Get yourself a late 70's Estate wagon, Country Squire, or even an Eldorado converable and you'll be fine
Morfoot
Grand Poobah Joined: February-06-2004 Location: South Lanier Status: Offline Points: 5313 |
I pull the 88 most of the time with a 00 Durango 4x4. It pulls it like no tomorrow and I'm not worried about any ramp I encounter cause yes it's in 4wd ALL the time which isn't all that great on gas milage pulling or not pulling the boat. Would I run out and buy a new one. I kinda doubt it with gas as high as it is. Didn't mind it as much when it was $40 to fill it up but now that its $80 or more it stings a little bit. You know the ramps that you encounter for most of your boating so that should help determine your towing need.
GlassSeeker
Grand Poobah Joined: November-26-2008 Location: Elk Grove, CA. Status: Offline Points: 2421 |
older tow wagons?
This is the life
GlassSeeker
2 wheel drive will work just fine.
I would think it might be hard to find a 2 wheel drive 4Runner? So if I were you I would get the nicest 4Runner I could find be it 2 or 4 wheel drive. |
This is the life
bhectus
Platinum Member Joined: July-04-2010 Location: Gator Country! Status: Offline Points: 1809 |
2WD all the way unless you are in the snow belt or have a need to use the 4WD feature for other things.
'87 Barefoot - sold '97 Super Sport Nautique - originally custom built for Walt Meloon '97 Ski Nautique '83 SN 2001 |
phatsat67
I enjoyed 19 Mpg at 70 mph yesterday in my full size quad cab 2wd truck into a head wind on a 150 mile trip :).
Limited slip is a must if you are going 2wd boat toater. I have only owned 1 open rear end truck and I hated it. That was the 5 speed Dakota 4x4. Being a stick with an open diff it wouldn't pull out a thing unless it was in 4x4. |
Keuka
Senior Member Joined: October-15-2009 Location: Keuka Lake, NY Status: Offline Points: 162 |
My Martinique will be a bit heavier than you SN plus I'm sure I have a fair amount of soaked foam adding to the weight. I tow with a Z71 Suburban and most of the time 2wd work fine. I have needed to use 4wd a few times though. The municipal ramp I normally use in natural shale beach. If it is real wet, I use 4wd. It is a nice option to have.
86 Martinique
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21142 |
Im a die hard 4wd guy for a number of reasons (snow belt, steep dirt driveway, etc), and would never consider NOT having it- but I recognize that 2wd may be sufficient on some ramps for many people.
That being said, I am totally lost as to why you'd ever try to pull a boat out of the water in 2wd if you have a 4wd truck. 4Lo gives a slow, steady pull, which makes loading easier- and its easier on the vehicle too. Seems like a no-brainer to use it if youve got it? |
bhectus
Use it if you've got it but why use it if you don't need it? No tire slippage, no need IMO. I will agree, it is definitely nice to have. The only regret I have with my 2WD is at the beginning of hunting season when the logging roads I use to get to my lease are still torn up from the summer rains and there's some deep mud holes. Having a locking rear diff definitely makes a big difference and helps a lot, off road and on the boat ramp. For me personally, the benefit of the up-front cheaper vehicle cost and the added fuel economy of a 2WD outweigh the benefit of a 4WD so that is the route I chose. I have had numerous 4WD trucks in the past and I just didn't reap the benefit down here in FL. But again, I feel it is location and personal preference specific. Need to weigh the positive and negative characteristics of each and make the proper decision for your own intended uses/needs and buy accordingly.
Another consideration is if your buying new or used.If a nice 4wd comes up in your quest it might be worth it. I have bought the full time transfer case in all my Jeeps.From November to April or whenever it rains it never comes out of 4wd. All but one has had posi,would not buy one again without it. Never have used low except on my home ramp and to put the boat in the pole barn for the winter,but than again my boats smaller than some of yours.
phatsat67
I love 4x4 but I couldn't stomach the change in payment. Maybe later on but as of now there is no need other than ego ;).
I used 4x4 on ramps if I had it. There is no reason not to kick it on if you have it. |
quinner
Key word Timmy is truck, those pertend jap car things they call trucks probably need all the help they can get getting over a speed bump let alone dragging a real boat out the water . The only time I ever needed 4wd as a necessity is launching / retrieving without a launch |
jbach
Senior Member Joined: September-24-2012 Location: Kentucky Status: Offline Points: 140 |
i little trick for those with 2wd and an open rear diff (one wheel peel). engage your parking brake about halfway down before pulling out. it will act as a limited slip and apply more power the the non slipping tire.
the same technique can be used for the front tires with the brake peddle if in 4wd. 4wd isn't really 4wd unless you have lockers (locked differential) front and rear. very few vehicles come with lockers (h1 hummer and wrangler rubicon are the only two i can think of). a rear wheel locker was an option on the 3rd gen 4WD limited 4runners. |
bhectus
I'll put my Jap truck against any 1/2 ton pickup any day of the week. Come on down CQ and I'll "show" you why it's better. |
quinner
OK dere Bert, thanks for the invite, will need to take a pass as I culd only imagine what you gurl car drivin fellas consider a pulling contest. The old double dutch rudder just aint my thing.
It would have to be down in Florida anyway Chris all the Jap ones here are rusted out.
bhectus
Aww come on CQ, I'm ready to put the smack back in smackdown. Had to post-whore on this one. 1000 posts! |
62 wood
I'm like Tim B. I have three trucks, ALL are 4x4's.
I have only owned one 2wd truck in 35 years and I wouldnt consider buying another. (I got stuck backing up to our house ... on WET grass) I understand a bit more operating expense, but also higher resale value when its time to sell. 4WD...."Dont leave home without it"! |
phatsat67
I bought my truck so cheap I couldn't pass it up haha. It's well optioned and had 20k on it a year ago when I bought it. Darn near perfect.
Had less than 18k in a 2010 truck when I walked off the lot! |
jbach
X2,i'll take ours over any domestic, pulling the boat or not. :stirthepot: plus, we prefer not to buy govt. bailed out, union built autos anyways. not only do they hold up better, they hold their value leaps and bounds better :stirthepot: |
phatsat67
I'm pretty sure no manufacturer really makes a "bad" truck. They all just have features and things about them that appeal to people differently.
