Engine Hesitation |
tiger
Newbie Joined: July-11-2006 Location: United States Status: Offline Points: 3 |
Posted: July-21-2006 at 11:09pm |
I have a 93 Ski Natique and I'm experiencing some hesitation when accelerating. It acts like it's starving for fuel, when I open it up it's runs fine but as soon as I back it off the throttle it starves out again. Could it be the water fuel seperator? Maybe some bad gas from the lake?
LakeBoy
Gold Member Joined: July-19-2006 Location: Roseville, CA Status: Offline Points: 709 |
When was the last time you changed the fuel filter? There are also a lot of little screens that can clog from where fuel comes out of the tank, until it hits the pump. Check for an in-line filter. My 95, which had little maintenance done on it before I bought it, was so clogged you could not blow through it.
83SN2001
Groupie Joined: September-07-2005 Status: Offline Points: 66 |
may be your accelerator( i know this is spelled wrong) pump on the carb. Check to see if gas squirts into the carb when you move the throttle arm.
GottaSki
Grand Poobah Joined: April-21-2005 Location: NE CT Status: Offline Points: 3340 |
Can't just be the accel pump if its starving when backing off...
from the given info, I suspect a piece of crap in the primary bowl plugging a main jet. Don't run it hard anyway unless for quick diagnosis, the lean condition can frag a piston or valve. |
River Rat to Mole |
tommer12
Senior Member Joined: February-05-2004 Location: United States Status: Offline Points: 366 |
I had my accelrator pump go on my 92... then my pv went also.
