Gelcoat Match |
Otto Throttle
Senior Member Joined: October-02-2017 Location: Cleveland OH Status: Offline Points: 385 |
Posted: July-30-2018 at 12:32am |
I have a small repai to make on the boats bottom. I need a source for a SMALL amount of repair in the beige Master Series color.....any suggestions.
Thanks! Otto |
Otto
gt40KS
Gold Member Joined: August-05-2017 Location: Wichita Kansas Status: Offline Points: 946 |
Call Nautique Parts to see if the beige is still available or call Spectrum Color directly. No one seems to list a Correct Craft beige, only the white bases. It may have to be custom matched.
JCCI
1995 Ski Nautique GT40 |
Air206
You will have to match the gel. I purchased the small Spectrum colors supplied by Nautique and they didn't match (or apply well if they are old - and most are kinda old). Years have altered the colors. My 91 base white turned out to need a hint of yellow to make it match.... and my deck gel after sanding is gleaming white - you would never think it needed yellow.
Donald80SN
Grand Poobah Joined: January-12-2009 Location: Denver, NC Status: Offline Points: 3896 |
Spectrum seems to only be sold through www.Iboats.com Normally, you will have to buy a large amount but it is a great match. Most colors are no longer available. I-Boats.com
BuffaloBFN
Is Mini-Craft gone?
Donald80SN
Nope, they are still around too. Mini Craft of Florida. It just seems that Spectrum was the gel company that Correct Craft used. I picked up some and it was a perfect match but i had to purchase a quart. I need a small amount of dark red and all they sell are gallons for Dark Red. Soon they want even offer it at all. My other option is Mini Craft or a mix and match kit by evercoat. I know Gary Starr has had good result with Mini Craft of Florida. |
It was good results in spite of them Don I had sent a piece in to them to match and it came back on the light side. I was able to darken it to what I needed. Was not worth the extra to cost have them do that.
The Spectrum match for the 95 was a little off also,too dark but that was on the 2 oz repair kit. |
GHTILL
Senior Member Joined: July-29-2018 Location: Aledo Status: Offline Points: 172 |
My repair from Spectrum that I purchased from NautiqueParts turned out to be pink for my 93' Silver cloud. Had to mix my own for further repairs. Using Gel coat repair from Polymerplanet. So far so good. The white gel coat base and mixed with their color pigments.
TWSS
BuffaloBFN
It's been some time, but mini was spot on for me.
Blamey
Gold Member Joined: August-18-2015 Location: White Plains,NY Status: Offline Points: 631 |
I had great results with the spectrum patch kit on my 09. Both the silver cloud and blue Valpour colors we're spot on.
Makes it less of an issue if I take a chunk out of the hull. My boat is also prone to spider cracks. Nice to know these won't cost me an arm and a leg. I do need some practice on my repairs but a couple I've done were undetectable. |
96 Super Sport
Previously: 95 Sport Nautique, 1980 Ski Supreme |
flyweed
Gold Member Joined: July-11-2016 Location: WI Status: Offline Points: 544 |
I too have had great results on my 93 silver cloud color with a small patch jar kit from Spectrum..it's ALMOST exact. not quite. depending on sun or daylight..you can see the new gel coat where I patched..just barely noticeable. I feel the old original gel coat is just discolored a bit from weather, water and time. In a year or two, the new will probably blend in perfectly.
GHTILL
This is what I would call pink. Nautique Parts sent another batch from the supplier which was a little closer, but still noticeable. |
TWSS
