1994 PLP multi coil pack testing protocol |
Author | ||
Kiwi Dave
Newbie Joined: February-11-2019 Location: New Zealand Status: Offline Points: 3 |
Posted: February-11-2019 at 10:11pm |
Hi
I've got a 1994 Ski Nautique with a PLP 5.8 lt Ford motor. This has been getting more a more difficult to start from cold (but runs and starts sweet when warm). I suspect there was a sticky needle valve in carb as it would always eventually stutter to life. Now it wouldn't even splutter. Plenty of power in battery so I've taken the plugs out and discovered a very weak spark so suspect also a fault in the multi coil pack, hall effect sensor (or something associated with this). Can anyone advise a protocol for testing with a multi meter to help eliminate or confirm my suspicions. Cheers |
Jonny Quest
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2942 |
Thanks(1)
Welcome Kiwi Dave.
A 1994 "PLP" engine with the 4-pack coils has the Pro-Tec engine management system that PCM developed in the early 1990's. Many PCM engines of that vintage had the Pro-Tec installed. I'm part of the Pro-Tec club as I also have a 1994 Ski Nautique with a "PLP" engine that came from the factory with the Pro-Tec system. The symptoms that you are describing are consistent with a Pro-Tec that is dying. My experience was similar. Start, then no-start. Then for no apparent reason, start again. Eventually, the Pro-Tec on my PLP engine finally died in the middle of a very large lake. I had to be towed back to the marina. No joy there. Now for the fun part...repair parts for the Pro-Tec system are no longer available. I called PCM and spoke with one of their senior technicians who was very familiar with the Pro-Tec EMS. He recommended that I completely remove the Pro-Tec system and retro-fit the engine back to a distributor based ignition. So, that is exactly what I did. As it turns out, several members on this forum have done the exact same retro-fit. The link below will take you to the discussion containing pictures an a tidy write-up of the procedure. LINK to Pro-Tec Swap-Out Thread Good luck. JQ |
Smithfamily
Platinum Member Joined: December-26-2007 Location: Orlando, Fl Status: Offline Points: 1602 |
Thanks(1)
Hello and welcome Dave!
I suffered the same with my 92 Pro tec. I bought the boat with a bad head gasket, rebuilt the entire engine, put it all back together and it ran great until the Coil pack started to break down. No parts available, and used was a consideration until I started to hear all the similar stories. I would just be waiting for another breakdown! Retro fitted to the old style distributor set up and no worries (8 years now) However make sure you get the high heat coil. Good Luck! We like to see pictures! |
Js
rosconole
Gold Member Joined: May-10-2008 Location: United States Status: Offline Points: 759 |
Thanks(1)
They quit making PCM kit , I think your 2 options are DUI distributor or MSD marine kit pretty much at this point . It a much happier engine with the old style setup. starting is much improved no random backfires. Make sure you close down the gap when you put new plugs in upon install. its a smaller gap on regular distributor. Just use an earlier year for reference.. Only difference in system is you have low pressure electric carb fuel pump.
1989 ski nautique ,1991 barefoot nautique, 1993 Mustang Cobra 1998 5.0 Magazine shootout invitee
phatsat67
Grand Poobah Joined: March-13-2006 Location: Indiana Status: Offline Points: 6150 |
Thanks(1)
MSD and DUI are likely the same or larger plug gap compared to the factory Pro-Tec ignition.
Plug gap is set based on the power output of the coil used in the ignition system. DUI is the cleanest easiest setup and likely most reliable. |
Orlando76
Thanks(1)
I believe DUI wants a .055 gap.
phatsat67
Thanks(1)
From memory I believe that is what they recommend. Install instructions will tell you when you get it. Stock Pro-Tec is .045
JPASS
Thanks(1)
DUI gap recommendation is 0.050 - 0.055
'92 Correctcraft Ski Nautique
Thanks(1)
Ross, Before someone makes a mistake after reading this, could you confirm the plug gap? It sounds like others have a different idea. |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11028 |
Thanks(1)
Roscoe You once again have a gap in your info A ProTec 454 had an electric fuel pump to supply the carburetor, a ProTec 351 with a carburetor has a mechanical fuel pump Another distributor choice is a complete Pertronix marine distributor for a 351w (only for normal rotation like Kiwi Dave's PLP engine. |
Thanks(1)
It's the Amsoil gap Pete |
rosconole
Thanks(1)
I have seen some that had an electric low pressure pump so , maybe in the change over year to year. .035 on the plug gap NGK usually comes out of the box around .036. , .050 is a little much for good idle quality from ones I have seen run. Maybe the DUI runs hotter and that is alot for any naturally aspirated engine, but I would bet if you close it down you would be suprised. I didn't recommend Pertronix because they have been not as reliable for me and a few other people. Its a decent product , Just support and reliability is not as good. I talked to them personally at trade show and they were not focused on marine market.
Thanks(1)
Ross, Sounds like you still are off on the gap especially with the "maybe" in your comment. So, I did a quick search on what is recommended. Here's what I found on the DUI: "Improved performance comes from our 50,000 volt coil and high dwell Dyna-Module. The coil allows spark plug gaps to be opened up to .055″. The increased dwell within the module makes the coil produce a longer duration spark. The combination of the two will provide the most complete burn of the fuel mixture possible." We sure don't want anyone gapping their plugs wrong after installing a DUI and getting surprised! |
phatsat67
Thanks(1)
Ross presents good info to show folks what not to do. So there's that?
Would be safe to say read the recommendation then do the opposite and you're golden, |
rosconole
Thanks(1)
its ok I can make instructional youtube videos for all you guys think I am full of it and everything on the internet is real life.
Thanks(1)
Rosco You've seen an electric fuel pump on a carbureted ProTec 351W, but......I've seen Elvis a few times myself.. I have to admit, I went out and looked at my old truck that has plugs gapped at .060 factory spec. I was looking for a supercharger or maybe a turbo that I never knew was there It wasn't there, what gives? By the way, I'll give you extra points for entertainment value, not many but a few. You do keep me laughing after all. |
rosconole
Thanks(1)
You should open your own Marine mechainic shop since you are all know on everything. You old truck with rust holes in the floor boards? Or was it a F150 that shoots spark plugs through the hood. Atleast I know why they have lifetime warranty on spark plugs now.
Ordered your commemorative Elvis plates for Christmas. |
Thanks(1)
Thanks(1)
We'll give you one more point for entertainment value, |
desertskier
Platinum Member Joined: December-19-2006 Location: Az Status: Offline Points: 1115 |
Thanks(1)
The coil kept the plug in the hole so no hood damage. Don't ask me how I know that! Also, I may have a couple of working protec units available this summer. I just ordered the parts for a DUI conversion. Boat still runs fine but I retired a few weeks ago and needed a project. I would prefer to give the parts to someone with an EFI boat since the carbed boat conversion is pretty cheap and easy. I will post them when I finish the swap. |
Kiwi Dave
Just to close the loop here with before and after photo's. Boat all fixed with power pack replaced with distributor and coil. I also managed to screw out the reductive starter motor prior to this all unfolding (a stupid design with tiny little plastic cogs used to drive the starter mechanism,) so replaced with an old school direct drive starter - bolted straight in. Installed two relays (one for power to new coil as was having voltage drop, and one for solenoid for starter as now drawing heaps more amps with the direct drive starter). Motor starts sweet as now, but yet to try it in anger on the river - hopefully this coming weekend. Thanks everyone for your comments and support Kiwi Dave |
desertskier
I think the relay for the ignition is a good idea. When I do the swap I plan on adding two relays for the ignition voltage. One N.O. in series with one that is N.C . The N.O. relay will be closed by the key switch voltage probably similar to what you did. The N.C. will be connected to the existing over temp and low oil pressure switches. If one of them detects a fault then the engine will shut down. The switches are open until they detect a fault then they connect to ground so the connection would be to the low side of the relay control.
