185 HP 292 intercepter parts |
RBranche
Newbie Joined: July-14-2024 Location: New York Status: Offline Points: 4 |
Posted: July-16-2024 at 7:11am |
New member, joined to make these parts available.have parts stripped from a 292 Y block intercepter short block.
Rotating assembly- crank turned .20/.30, pistons and rods, bearings were just starting to show copper. Cam, lifters, timing gear set, believe to be reverse rotation, lifters were removed in order to match cam Dual carb down draft intake with water connections, valve covers, bell housing, engine mounts, oil pan, timing cover and fuel pump. I have no use for these parts but someone on here might, would prefer to sell as a package. May be able to help with delivery along the I81/I95 corridor between NY and Florida in the next couple weeks otherwise local pickup, to heavy to ship. Pictures available by email. Asking $500 OBO for everything. Thanks, Ron jayare4@verizon.net |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11022 |
Is that timing gear set a chain and 2 gears or 2 gears that mesh with each other and no chain?
2 gears and chain would be normal rotation 2 gears that mesh and no chain would be reverse rotation. I'm not interested but if you verify what you have, it'll probably help you sell the stuff. |
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21166 |
Might also help if you list your specific location in your ad or profileā¦ NY is a very large state.
RBranche
2 gears that mesh which led me to believe it is counter rotation. Thanks, Ron
RBranche
Watertown, New York, 60 miles north of Syracuse.
will assist with delivery if possible. Thanks, Ron |
