camshaft and seals needed |
boat dr
Posted: January-09-2010 at 1:06am |
Thats Karens # Magic Jack............Mine is 1-318-386-2825
rookie
Groupie Joined: July-26-2009 Location: florence,ms Status: Offline Points: 74 |
boat dr ...is that a la. prefix? if so i can drive over and get what i need.
dave |
do it right the first time...
boat dr
CorrectCraftParts...........Karen
1-318-299-8547 |
rookie
thanks you guys are great... pat at marine engines reman. said that the the parts book called for directional seals but he did not have them. of the information offered who is a member as i would like to give my business to them first.
thanks rookie |
Waterdog
Pretty sure the 1 peice r/main seal is 85 & newer. I looked all over, SECC sent me one for around $90. If anyone knows of a cheaper one, I'll take two for my other blocks.
When I bought my cam from Scott at Cam Research I also got a R/R gasket set - Not. He was great to work with let me keep the std. marine gasket kit AND sent me a windage tray for the hassel. Cam Research = Good People. |
critter
Platinum Member Joined: January-11-2008 Location: New Hill, NC Status: Offline Points: 1227 |
Good point Tim...
My 80 had the wick lines on the crank. I suspect that the 78 would also have the wick lines. That would result in a smooth seal needed. The part numbers above are for smooth seals. |
1980 Ski Nautique
1966 Barracuda |
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21135 |
At some point, Ford switched from having directional seals and smooth cranks to universal seals and wick lines on the crank. Or is it the other way around? And what year did they switch? I think Ive read early 80's.
Either way, might want to verify which set up you have to make sure you order the right parts. |
WakeSlayer
Boat dr will have them too,
1-318-299-8547 |
Mike N
1968 Mustang |
critter
Marty helped me with the part numbers of the RR seals from CarQuest.
The important ones for RR are the Timing Chain Cover seal and the Rear main seal. Skidim # 1139 = $75.81 (Rear Main) Fel-Pro # BS-400-42 = $10.00 (Rear Main) Victor # JV614 = $ 10.00 (Rear Main) Fel-Pro # 17795 (Timing Cover Seal) = $20.00 |
1980 Ski Nautique
1966 Barracuda |
WakeSlayer
I believe you need to make sure you have RR crank seals. Not the automotive ones.
Mike N
1968 Mustang |
critter
I think the cam can be ordered from Summit or Jegs online. Or you can order one from Research Cams if you are perking up the motor.
What seals ? Most seals are available from Napa or CarQuest Auto parts stores. |
1980 Ski Nautique
1966 Barracuda |
For the cam, call Cam Research.
rookie
I am rebuilding a 78 sn and need a right hand turn cam and multidirectional seals for the 351w...any idea who still sells that stuff? it is a chain set up and not gear driven.
thanks rookie |
