electric diagram ski nautique 1976 |
dwcar
Platinum Member Joined: February-11-2007 Location: Houston Texas Status: Offline Points: 1103 |
Thanks(1)
Posted: June-30-2012 at 10:42am |
Antoine ,
The Ski Nautique on the outside of your boat was painted on. You should tape off the old letters and re-paint them. Corret Craft used a paint called rustoleum. As far as the decals on the back end of your boat, I believe that another member here on CCFan has them. Look in the member list for Pauly-banana. |
83Ski
Thanks(1)
Adam,
You are correct that the diagram you posted is a good one. It's pretty generic for any engine/boat back then. The only "trick" that OMC may have installed is the diode in the alternator circuit to prevent a back feed/discharge when the engine isn't running. |
antoine
Newbie Joined: June-29-2012 Location: France Status: Offline Points: 9 |
Thanks a lot, i will do my best to make it work ! have a nice day.
Antoine |
adamt
Gold Member Joined: July-18-2007 Location: Orlando, FL Status: Offline Points: 927 |
Thanks(1)
I would feel better if someone with more knowledge than me would confirm it, but I think this is the right one... |
antoine
Hi,
Could you help me to find an electric diagram for Correct Craft model Ski Nautique 1976, powered with a 260 OMC engine in order to repair mine ? I am also looking for the stickers all around the hull, is it possible to have them in france ? Thanks a lot. |
