The 81s ready to roll |
81nautique
Grand Poobah Joined: September-03-2005 Location: Big Rock, Il Status: Offline Points: 5775 |
Posted: May-03-2006 at 9:09pm |
raygunclan.
All new wood. It didn't look that bad until I started taking the skins off, pretty much just fell apart after that. If you have basic carpentry skills and tools you can do the job in a couple off weekends. I used bisquits for all joints, they help you line everything up during assembly. Then used a waterproof polyurethane wood glue like Gorilla Glue. I then used a countersink drill bit and stainless steel screws. Then I coated everything with resin and put a strip of fiberglass on all structural corners. My method is total overkill but I don't think I'll have to worry about this again for a long time. |
raygunclan
Groupie Joined: March-21-2005 Location: United States Status: Offline Points: 57 |
was that the original upholstery bones or is that all new? we are in need of upholstery and i want to do it myself, but i'm not sure if it is a "job for superman" or not!
thanks! |
who needs a mortgage when you have a boat!?!?
ultrahots
Gold Member Joined: September-08-2004 Location: United States Status: Offline Points: 618 |
Simply AWESOME.Last time I saw that poor boat I was thinking PARTS !! Now it looks to be the star of the fleet.Mine Hopefully should be complete before the Green Lake event.Getting ready to shred the floors with a little help this weekend.Been measuring and taking pictures for the last 2 just so it goes back together right.
rleinen79
Gold Member Joined: December-16-2004 Location: New Carlisle IN Status: Offline Points: 733 |
81 - I have a feeling that's going to be the talk of Green Lake....can't wait to see it in person. Looks absolutely GREAT!!!
81nautique
Oldcentury,
The rub rail is original and once again I put in a lot of time with a buffer. I went to Home Depot and bought a small buffing wheel ( about 5" round) and put it in my hand drill. I used a fairly course compound and buffed the snot out of it. The finished off with neverdul and a coat of wax before putting it back on. With the course compound you can actually buff out small scratches. It came back very nicely with a bit of elbow grease. |
oldcentury76
Newbie Joined: September-23-2004 Location: United States Status: Offline Points: 34 |
I read your diary, did you replace the rub rail when you painted? I have a stainless rub rail and mine is pretty scuffed. If you replaced it where did you find one?
81nautique
oldcentury76,
After we painted the stripes with color we clear coated them so all blue paint is cleared. I wet sanded and buffed the stripes but that was actually buffing the clear to a nice finish and that also softened the edges of the stripes. After I finished that I waxed the entire boat(gelcoat and cleared stripes) and buffed that off with one of those orbital polishers just like you would a car finish. We put a fairly heavy clear coat on so if I get any scuffs from dock bumpers as long as they don't go through to the color I can just wet sand and buff them out again. Time will tell if this was the right approach but I'm very pleased with the finish. |
oldcentury76
81nautique,
you state "We used base coat with a clear on top so the clear had to be wet sanded with 1200 and buffed again but the shine and finish is like glass. " Are you talking about the painted surfaces? If so can you now wax the boat with out taping the lettering? I am going to do the same thing you did, to my boat next winter. I was hoping that after I redo it I won't have to worry about waxing my boat and having the blue paint stain the gelcoat. I was planning to put a clear coat over just the lettering so this would fix my problem. |
81nautique
Jbear,
The old stripes were removed by hand wet sanding and took me a couple of days and quite a few blisters. I also wet sanded all the gel coat to get some shine back. Then buffed the entire boat, several more hours. We used base coat with a clear on top so the clear had to be wet sanded with 1200 and buffed again but the shine and finish is like glass. A lot of work but this one is my keeper so I thought it was worth it. |
David F
Oh yeah, nice job 81nautique, your boat looks great!
David F
No, no magician...I can't match colors worth beans. I go the easy and expensive route by purchasing pre-matched gel coat through my local CC dealer. The color match adheres to my 5' rule: From 5', you cannot tell the difference or see the blend line. However, from 1', you can see, but just barely. If anyone is going to the Reunion in San Antonio, the boat and I will be there even though the price went from $7/head to $20/head this year |
jbear
Alan: Am I reading you right: you did it all with a buffer, not by hand? I have been delaying because I was afraid to get into a big job. But it sounds as tho with the right stuff it can be done in a day? Hard to believe, because it looks so good!
Gary: I remember now. Senior short term memory is bad! We live in the center of the stste. 8 hours from the Keys. Wish we could see ya but it's way to far. Maybe next time. You are gonna love it there. Have a great time! john |
"Loud pipes save lives"
81nautique
Thanks everyone, I'm pretty happy with the results although I learned a lot and would do a few things different next time. I'll be redoing the gel coat repairs over again next winter because i did a crappy job matching the color, DavidF must be a magician because that ain't as easy to do as it sounds. I'll just use it as is this summer, time to start having some fun.
62, Lousy weather right down to the end. I had the boat at the body shop for 2 weeks waiting for it to be wet sanded and buffed. I finally picked it up Sat afternoon and it had not even been touched. I stole a buffer, paper, compound and took the boat home and got it done in a couple hours Sunday in the rain. I wonder how long it will take before the body guy notices that it's gone. One thing for sure is he won't get his buffer back until I get the touchup paint he promised. Lesson learned, DO IT YOURSELF. The motor on this one is solid and I don't want to touch it. So I'm now in the market for a basket case Tique or something smaller that I can take my time on and turn into a little hot rod. |
Mojoman
Senior Member Joined: October-31-2005 Location: United States Status: Offline Points: 553 |
Alan,
Way cool !!! That rig did come out sweet !!! Can't wait to see it on Memorial Day... Really nice job "Magic" !!! Moj' |
stang72
John...I did mention it a while back...we are going to be in Key West. Leaving Thurs and flying back tues.How far are you from the Keys?
SMay81SN
Groupie Joined: June-22-2005 Location: United States Status: Offline Points: 92 |
Magicman-Alan,
Sweet looking! Great job. Nice to see an 81 looking better than new! |
Scott
Our 94 SN |
62 wood
Alan,
Awsome job! The thing that makes it even more amazing is knowing the "wonderful" northern IL winter conditions that you did most of the work in!!!!!!!!!! jbear , you got that sandpaper out yet? |
bkhallpass
Very nice Alan. Looking forward to a ride in Green Lake. BKH
Livin' the Dream
jbear
Alan (aka; magicman); WOW...WOW!! Boy you must be PROUD! What a job! Really like the look of the white and woodgrain dash. Can you get a pic of the dash on also?
Gary: Did I read correctly that you are coming down to FLA? I think we might have talked about this before but...me and mrs jbear would love to meet ya if you are gonna be close (do I remember Disney?) and have a little time. If so and you want my numbers send me a e-mail, it is in my profile. john |
scott8370
Gold Member Joined: November-30-2005 Location: United States Status: Offline Points: 872 |
Love that BOAT!
Scott
Atmspltr
Senior Member Joined: May-04-2005 Location: United States Status: Offline Points: 170 |
Beautiful job...you should be proud!
RB |
stang72
WOW! Alan...I knew you were going to make it nice...but thats really nice. Outstanding job my man!
You are the magic man bro! Hey, I am real close with the 72...going to Fla for a week and should have the seats done when I get back...paint the graphics and done! Well...like you I have some trailer work too! Can't wait to see the 81 in person! Did I say WOW...WOW! |
81nautique
Well here's a couple of quick snapshots between rain drops today of my winter project.
New goodies include, all new interior, carpet, new fuel lines, electronic ignition conversion, wet sand and buff the entire boat, striped and repainted stripes, wet sanded and buffed stripes today in the rain, depth sounder, low oil presuure/ high water temp alarm and basic tune up, OJ dripless shaft seal Still on the list is to install new bunk carpet and we plan to paint the trailer to match the blue of the new stripes. Oh yeah, and I gotta replace those galvanized wheels some day. Thanks to the many folks who provided tons of info on this site so I could get this done. |
