Aqua Signal light pole bracket? |
Dank
Senior Member Joined: April-05-2005 Location: Austin, TX Status: Offline Points: 296 |
Posted: June-06-2006 at 2:37pm |
Yep...it's the "stern light base only, all Nautiques from 1986 to 1992". I'm ordering one right now...Thanx!
"I don't know what the world may need, but a V8 engine's a good start for me"
jimbo
Does it look like any of these?
http://www.whitelake.com/catalog/lights__stern_409225_products.htm |
Dank
So I searched the forums and I googled Aqua Signal and so far I haven't come up with exactly what I'm looking for. My anchor light pole bracket is broken and needs to be replaced. The current one is an Aqua Signal, but I don't have a part number (there might be one on it when I actually pull it off the boat). I've found Aqua Signal on the web, but from what I can tell it doesn't seem like they make light pole brackets anymore. I bought a perko from WM, but it's quite a bit longer. The AS is real short. I'd like a direct replacement if I could find one so I don't have to drill any new holes. Any leads?
