91 nautique excel will not throttle up under load |
Post Reply | Page 12> |
Author | ||
rosconole
Gold Member Joined: May-10-2008 Location: United States Status: Offline Points: 758 |
Posted: July-10-2018 at 3:36am |
Did you get the leaky trans issue figured out sounded like it was over filled.... or loose hose
1989 ski nautique ,1991 barefoot nautique, 1993 Mustang Cobra 1998 5.0 Magazine shootout invitee
Shua4242
Newbie Joined: June-24-2018 Location: 45880 Status: Offline Points: 28 |
Well thanks for all the hep guys, I finally have a boat. The engine wasnt running right because of a fuel problem, I believe it was the anti siphon valve as it was dirty. But I did also change the fuel filter so it could of been that. The tranny issue was the previous owner had the linkage on the tranny wrong, when it was in gear, the pump was not working. I will create a new thread on how I swapped an 89 truck engine into a reverse rotation boat engine since I know know my problem was only fuel.
Shua4242
That is how mine acted, easy with a screw driver but hard to blow, I am going to try the new coil on the water tomorrow and I will post back on how the trip went.
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10745 |
I have a new one on the workbench and I couldn't blow hard enough to unseat the ball. If you take a little screwdriver and push on the ball, it should move very easily and the spring will reseat the ball when you remove the screwdriver. A little hard to quantify "real easy" but hardly any force is required at all |
Shua4242
I believe my anti siphon valve is the culprit, I could not blew through it with my mouth, How hard are these supposed to be? I will get a new one tomorrow and take it to water to find out.
Shua4242
Yes, I live in Ohio but right on the state line of Fort Wayne, Indiana
Air206
Wish you were closer, I'd help you. Always good to meet an Excel brother.
Ft. Wayne area, right? |
Air206
Years ago, I worked out a CCFan discount 20% - It may be worth asking. You go directly to WEMA............ If not, at least ask for free shipping.
Shua4242
My sender does not work, so I will measure and order that one ou are talking about, and okay, I will pull that out and check and clean it, as it is the only thing I have not had apart or new for the fuel system. I will do this tomorrow night and let you know.
Air206
Since you'll have the rear bench out and the floor off, It is a good time to switch to a WEMA sender for that tank. (stick, rather than float arm). Measure to the tank bottom through the sender hole. Order a sender 1 inch shorter than the tank (11 inches IIRC for my Excel). They are worry-free and tame that big tank slosh better. Original gauge is 240-33 ohm American Stewart Warner type (Not European, 0-80 ohm).
Here's a picture anti siphon valve s on the left, the suction tube for the tank is on the right
It's a good time to blow out the suction tube too. |
Don't pull the sender, the anti siphon valve is external on top of the tank. The hose to the fuel pump connects to the valve. unhook the hose and unscrew the valve. Then you can see if it's plugged with debris. It looks just like a barbed hose fitting, but there's a ball and spring inside of it |
Shua4242
I never knew there was a valve in the tank so I will pull the sender and check it. Thanks for the help guys.
Shua4242
I had a professional rebuild the carb while I was rebuilding the engine, he told me how to adjust the air screws, I got the one side to adjust but the other side would not make a difference if I screwed the screw all the way in or out. I will check the coil.
JohnH
Newbie Joined: April-07-2017 Location: Rocklin, CA Status: Offline Points: 2 |
I installed a Pertronix distributor and coil on my BB chevy and it ran great for about 50 hours. Suddenly I had the same symptoms as you: it would idle and rev with no load but would not accept throttle under load. The problem was a bad Pertronix coil. I changed it for a generic GM oil filled coil and it was back to running great.
So how's your carburetor?
Idle mixture screw adjustment good ? Accelerator pump adjustment/clearance as it should be? How's the anti siphon valve at the gas tank? |
Duane, You didn't read the events in the order they occurred. I've done it too! I brought up the alignment as a possible cause BEFORE he checked it. Then of course Gary has to step in and work me over for even bringing up the alignment! |
Duane in Indy
1978 Mustang (modified) |
Gary's not saying your cam is wrong. He's giving you an example of what happened to him with firing order, plug wire mixups, but you've obviously at least double or triple checked all this so it must be something else |
Shua4242
I know the cam is correct as it was an original one with the factory motor
Let's not get hung up on firing orders as a possible cause of the engine running right. Gary, My early thought was since the engine was just dropped in without an alignment it could have caused such a bound up prop shaft that could limit RPM's |
Years ago, before this site, when I rebuilt my HM 302 in the Mustang,I bought a reverse rotation cam from Crane. Used the firing order on the cam card and ran it in at 2k at the dock. Went to go for its first drive ran much like yours. Long story short the cam card showed the reverse 302 firing order when in fact they ground the cam to the reverse 351 order which is different. I had to pull the valve covers,turn it over by hand and watch the rockers in order to figure out what they did. Just saying.....
Shua4242
Figure 6 matches the numbers on the tag on the engine, and that is the way I have it set, because I had originally thought it was a couple crossed wires.
But what is the firing order?
People have screwed up their firing order,cylinder numbering, mixed up a couple of plug wires etc and had those same symptoms trying to accelerate which were magically cured when they realized it and then got it right Here's a picture |
Shua4242
It is a RH engine and I have checked the firing order and plugs, all match up. I just did the alignment, and it was already perfect.
Far from an Excel expert but they had RH engines at that time. Here's an old thread Gary, complete with pictures old thread |
Where are our Excel experts?? By that time frame '91 were they using right hand engines? By then most SN were using lefty's
What's your firing order and have you double checked that the wires are run correctly?
Shua4242
I did miss that point, I will loosen the bolts and do the alignment that way, Thanks for all the input I have gotten from everyone as I would like to have this sorted out before July 4th
Shua4242
At idle and on the trailer it sounds like it is running just fine, but when I try to set the timing, i cant quite get it to run at 10 degrees before tdc, it isn't happy there but will run if I adjust the idle speed up higher, and I did the rebuild because I bought it In the Fall last year and the previous owner did not winterize it right (the block was cracked) I did not know this until this spring when I took it to the lake and after aout 2 hours it was full of water. I used the block out of an 1989 ford truck with my camshaft and the truck bottom end, the truck motor only had 20,000 miles on it. The crank is drilled both directions so it can run in reverse. This is the same ignition system as last trip on the lake when the engine filled with water. (engine ran fine then)
