Looking for anExhaust Flapper.. |
79nautique
Posted: August-11-2006 at 11:46am |
Steve if you cann't find the correct size I would just cut the ring section of the rubber in the center lower section and then over lap the two pieces then take a razor blade and make one cut throught both and remove the ends so that when the clamp is tightened they but up together and look like a continous ring without a gap if you are forced to use the 3" versions. What hose ID are you using?
fredo68
Senior Member Joined: April-03-2006 Location: United States Status: Offline Points: 138 |
smallest you can get is 3 in. just cut half inch out of bottom of rubber, anymore and they
wont stay on no matter how much you tighten them down...from experience. |
fredo68
weitekampt
Senior Member Joined: July-08-2006 Location: Fisher, IL Status: Offline Points: 457 |
I actually have 2 new flappers that were going to go on a 85 SN. If you want them, I have em.
todd@agsourceseeds.com or weitekampt@aol.com Look forward to hearing from you! |
Tim D
Grand Poobah Joined: August-23-2004 Location: United States Status: Offline Points: 2637 |
I put 3" on my '66 Mustang. Just pinch them tight with hose clamps. You could cut a notch out so it will squeeze in smaller. Mine have very small ripples.
Tim D
62 wood
Does anyone know where a person can get an exhaust flapper for my 64?
Its exhaust is only 2 3/8" os dia. I can find 3" and larger, but no luck on a smaller one.. I do have a homemade one on for now, (made from a neoprene pipe cap).. but Im not crazy about the look.. Any help? |
