gt 40 injector removal ? |
malibud
Gold Member Joined: July-08-2009 Location: north carolina Status: Offline Points: 612 |
Posted: April-29-2024 at 8:51am |
Hey thanks Jonny ! huge help ... hopefully I'll be able to pass on the knowledge...
Jonny Quest
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2865 |
It is MUCH easier if you remove the intake manifold. As long as you are working on the EFI system, a new fuel pressure regulator may be a good idea -- fairly inexpensive and may save headaches down the road.
What are you going to do for the injector replacement? If you buy a PCM injector, they are quite expensive. The FoMoCo part number for the same injector is: F1TE-D5A. These can be expensive. You can upgrade to new injectors for under $250. Ford Performance 24 lb injectors. https://www.summitracing.com/parts/fms-m-9593-lu24a You will also need some EV6 to EV1 adapters so that the new injectors work with the existing wiring. https://www.summitracing.com/parts/btc-ev1ev68 JQ |
malibud
I have one leaky injector 1st one behind the drivers seat. I searched but....
Does the intake have to come off or can I slide it in ? thanks !
