bad coil pack? |
robsch
Newbie Joined: May-11-2005 Location: United States Status: Offline Points: 8 |
Posted: June-25-2007 at 2:23am |
Does anybody know if there is a coil pack converstion for the 454? I didn't see one at skiDIM. My dealer is having problems finding replacment parts for same (occasionally not firing on a couple of cylinders) and it sounds like these coil packs are just problems waiting to happen. Thanks, Rob |
91sporty
Newbie Joined: May-29-2007 Location: United States Status: Offline Points: 15 |
Thanks quinner, I'll call Vince.
quinner
The ProTech on our Carbed Pro-Boss 93' puked in 04', symptoms where after it warmed up it would not restart until it cooled a bit with the dog house open and also some misfiring at higher RPM's. Call the guy's at SkiDim, they know that Protech system very well if that in fact is the problem.
BTW, the upgrade kit IMO made that motor run stronger than it ever did with the ProTech. Good Luck |
91sporty
carb
79nautique
FI or carb motor?
91sporty
Thanks Backfoot,
I checked that kit and it's $450something, I'd order it in a minute if I new that would fix things. It just sounds like an ignition problem to me but others have said it sounds like a fuel problem. |
backfoot100
Welcome to the forum Sporty.
I'm not that familiar with the Pro Tec, but from reading other posts, that ignition system is somewhat suspect after about ten years and finding parts for it are tough. I believe each coil pack runs two cylinders and that could certainly be an issue however I don't know for sure. I know that SkiDim sells an upgrade kit that eliminates the Pro-Tec and puts in a conventional electronic distributor that others have done on this sight with a lot of success so they would know better than me. |
Eddie |
91sporty
I've got a '91 sport nautique with the pro tech ignition system. Boat starts and runs good, but after about 5-10 minutes on the lake it dies, starts back up and continues to die more frequently until it won't really run.
When it dies it's like someone turned the key off. Sometimes it won't rev over 2000 rpm (sounds like it has a rev limiter) Has anyone ever experienced this? Could it be the coil pack? Please help |
