Throttle will not stay in position |
eric lavine
Posted: June-13-2007 at 7:21am |
I just took apart a couple of remote controls and noticed a couple of adjustments and one said "friction" on it, so i know there may be adjustments in the controller if you remove the cover
behindpropeller
Nut on the back of the morse control, tighten it up a bit.
Cable age has nothing to do with throttle creep. Tim |
79nautique
no get a new cable or check the return spring on the carb to see if someone has but a heavy spring on it. |
Hamlin
Groupie Joined: November-19-2006 Location: United States Status: Offline Points: 57 |
Would you consider using something like this?
Cable Brake Manufactured By: Morse Controls (Teleflex/Morse) Item Number: MOR 44386 Do a search on 'Morse Cable Brake #MOR 44386' |
Tim D
Grand Poobah Joined: August-23-2004 Location: United States Status: Offline Points: 2637 |
Can be a sign of a worn out cable. Has the cable been bent?
Tim D
89, I seem to remember this coming up before. Do a search for the topic. I also think it turned out to be a safety feature that was added on later boats.
89Nautique2001
Newbie Joined: May-07-2007 Location: Lake Delhi, Ia Status: Offline Points: 31 |
My throttle will not stay in position, I have to hold it there or it will creep back to idle. Is there a way to tighten this up? Thanks
------- They are only original once! ------
