  New Posts New Posts RSS Feed - Am I slipping?
Am I slipping?
mars88 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mars88 Quote  Post ReplyReply Direct Link To This Post Topic: Am I slipping?
    Posted: June-05-2006 at 5:45pm
Hey guys i have a quick question. When I put our boat(88ski) in gear and the throttle "clicks" it seems like the boat isnt going into gear. If you give it more gas then it will engage and go forward. you can let off the gas for a slower idle once it engages ut seems to me like it wont catch and go in gear. I checked tranny fluid and everything is ok. I just want to catch something before it gets really bad. Thanks for any suggestions.
mars
Tim D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: June-05-2006 at 5:54pm
Sounds like your cables are not in sync.
Tim D
mandovoodoo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mandovoodoo Quote  Post ReplyReply Direct Link To This Post Posted: June-05-2006 at 7:46pm
How do you synchronize the cables optimally? I'm not suffering ill effects, but I think things could be better.
www.mandovoodoo.com
mandolin research
1986 Martinique, TN
Munday View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Munday Quote  Post ReplyReply Direct Link To This Post Posted: June-05-2006 at 8:12pm
Put control in dead up neutral
disconnect trans cable
move arm on tranny till you feel indent
now adjust cable till it slips right on
tight backer nut and you got it
Good luck munday
David F View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: June-06-2006 at 10:24am
That is only half the story. You must do the same with the throttle cable, BUT you MUST adjust the throttle cable with the throttle lever just IN GEAR. This method properly loads the spring at the throttle control.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mars88 Quote  Post ReplyReply Direct Link To This Post Posted: June-07-2006 at 11:29am
could the idle be too low?
mars
