Am I slipping? |
mars88
Senior Member Joined: November-06-2005 Location: United States Status: Offline Points: 104 |
Posted: June-07-2006 at 11:29am |
could the idle be too low?
mars
David F
That is only half the story. You must do the same with the throttle cable, BUT you MUST adjust the throttle cable with the throttle lever just IN GEAR. This method properly loads the spring at the throttle control.
Munday
Gold Member Joined: August-17-2004 Location: United States Status: Offline Points: 538 |
Put control in dead up neutral
disconnect trans cable move arm on tranny till you feel indent now adjust cable till it slips right on tight backer nut and you got it Good luck munday |
mandovoodoo
Newbie Joined: April-16-2006 Location: United States Status: Offline Points: 22 |
How do you synchronize the cables optimally? I'm not suffering ill effects, but I think things could be better.
www.mandovoodoo.com
mandolin research 1986 Martinique, TN |
Tim D
Grand Poobah Joined: August-23-2004 Location: United States Status: Offline Points: 2637 |
Sounds like your cables are not in sync.
Tim D
mars88
Hey guys i have a quick question. When I put our boat(88ski) in gear and the throttle "clicks" it seems like the boat isnt going into gear. If you give it more gas then it will engage and go forward. you can let off the gas for a slower idle once it engages ut seems to me like it wont catch and go in gear. I checked tranny fluid and everything is ok. I just want to catch something before it gets really bad. Thanks for any suggestions.
mars
