98 Ski Nautique Blowers are LOUD! |
Post Reply | Page <12 |
Author | |||||
Bri892001
I run mine intermittently. Once at startup, then, every time I slow down and stop to change skiers, I run it for a few. Then I'll run it for a few before I cover up the boat when I'm done with it. I agree that when you're moving forward you don't really need it.
Are these things like bath fans? By that, I mean, will a few extra dollars spend on a better quality replacement give you lower sound levels? |
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Online Points: 21137 |
You got an explanation as to what is causing your noise, as well as the probable root cause as to why the blower is starting to fail. You even got some insight into the technical parameters involved. You also got good advice as to what to do (buy a new one and replace it) and where to get it. Seems like this thread has come full circle... why is it still going? |
kapla
wonder the same Tim...its a blower!!! $50 go buy a new one a forget about it!!!!
IntelSoftApps
Senior Member Joined: April-12-2011 Location: WA Status: Offline Points: 144 |
Like i said before... What do you think i am doing!
I know about the vent system while moving and i know lifting the engine cover is a good idea. Its common sense. I know why the blowers are there too. I was forgetting about this, but then some moron wanted to get all scientific with this and see there are only ONE blower not blowers. Then another idiot said i wasn't reading the posts. If i wasn't reading the post how would i respond to the posts and i wouldn't be getting a new blower. And yes the BLOWER is cheap, but they should not be as loud as mine. They are pretty quiet when new. So thanks to all who helped and not thanks to who all didn't. I am getting a new BLOWER and will install it and it will be quiet. If anyone else responds to this post saying i am not listening... They are the ones that keep going on with this whole thing because i READ THE POSTS and i FOLLOWED what they told me to do! |
DrCC
Sorry, Thought you meant this type of Blower. |
OverMyHead
The CCF path is rarely a straight line. You can learn more here by accident than by design from most other sources, nothing wrong with a little extra background or an opportunity to for others to get some of their questions discussed also. Its not always just whats in it for YOU. |
1987 Ski Nautique |
IntelSoftApps
Ya thats fine, but then he cant go and blame me for not reading the posts! |
east tx skier
Senior Member Joined: August-22-2006 Location: Tyler, TX Status: Offline Points: 248 |
Ha! I just googled the same thing. My 98 SN Blower sounds like a bad power tool. I bought another one and thought I'd get a heads up on how they go in before diving into it. I run mine before the initial startup and usually on subsequent startups if things have been sitting for a while. With gasoline vapor being more dense than air, I'm not confident that just opening the motor box is going to do much with any vapor pooling in the bottom of the bilge. This is my method. If what other people do has not caused their boat to become a briquet, more power to them. |
Fibersport
Groupie Joined: September-30-2008 Location: Lansing, IL Status: Offline Points: 76 |
Not to challenge anyone, just would like to make a correction for those that followed Pete's engineering analysis on electrical load and the horsepower loss. Pete, you're off on your wattage, should be 36 watts (3A x 12v). I've looked around and found that a 60 amp alternator draws about 1.5 hp, the 3 amp blower really wouldn't add that much draw, in the order of 0.056 hp (36W x 0.00134). Add the two together and you end up with about 1.556 hp.
IntelSoftApps
Let me know hoe it goes! and if the blower is quieter! It seems like the 98's are the blower problem boats... |
Bri892001
Maybe it has something to do with the location of the blower on the 98s?
On the older boats, there pretty much under the motorbox. |
east tx skier
Will do. but I don't know of I would call a blower that still works after 13 years a problem. |
IntelSoftApps
I didn't mean like the whole thing is a problem. What i meant is that the loudness of them after awhile is always in a 98 ski nautique. Also, did you ever post a story or post about your boat??? It looks very familiar. Like i have seen it online a few times... |
lewy2001
Just replace that blower please
IntelSoftApps
Im working on it lewy2001
east tx skier
I know. Mine has always been noisy for sure. I posted a review about it on fifteenoff.com about it several years ago. I have certainly posted pictures of it on this site and others. Good chance you have seen some of the pictures before. I get around to quite a few boat forums (and that's probably putting it mildly). |
IntelSoftApps
Thats right! I remember now. Anyways, nice boat. I like the colors
