Seafoam Uncovered |
Posted: September-27-2011 at 12:59am |
In decided to search for more info on this topic. You can believe everything you find on the web, right?
Well, I think Joe ('89 Martinique) has a good point on Seafoam. I found several references on which people ended up with spun bearings after adding it to their oil, which is recommended on the Seafoam website. Apparently, Seafoam is naptha & alcohol & thins out oil too much. I saw no reference to a problems when added to fuel. |
who the fck ever said to add that sht to their oil? maybe i missed something. and why would you add it to the oil?
to add, if you are selling something thats the only time you throw a jug of lucas in the crankcase, firsthand my neighbor loves the *************** and swore but it....well, I pulled his valve cover on his jeep (because it was a knocking) and that thing was so gummed up the lifters were hanging, religously changed his oil and added a qaurt of lucas every 10 thousand miles. the only thing that belongs in a crankcase is oil, if you need to add some type of molasses to a crankcase you have a problem that isnt going to miraculously dis-appear with a can of goo. this sht was created to hide a problem, used car guys own stock in that company. btw, I had to use that sht in my villager van, only cause the oil light would pop on at idle in the summer, but it was a work van and i knew it wouldnt be long. |
10-4 Eric - The only thing you should add to oil is more oil
OverMyHead
Eric, I dont have the can in front of me , but I believe seafoam advertises itself as a water removal agent when added to oil, to be used after a bad head gasket or similar incident.
1987 Ski Nautique |
mdvalant
Use it in my oil all the time. Shuts the lifters up, def does thin the oil out though. I put it in for a thousand miles or so to clean it up then change the oil again without it.
I really love it. My accord's valves were ticking like a SOB with 200k on it, put sea foam in the oil a couple times and it doesn't make a peep at idle now. I was very impressed. Straight from their site: "To clean oil rings and lifters, add 1½ oz. Sea Foam® to each quart of oil. Sea Foam® will slowly re-liquefy the old oil varnish residue that builds up on lifters and rings and prevents them from functioning normally. This process can be done as part of a pre service cleaning by adding the Sea Foam® to the oil at least 30 miles before the next oil change interval. OR it can be done as a preventative maintenance process without changing the oil. You can leave Sea Foam® in the oil indefinitely as long as the oil is clean. The addition of a high-detergent oil like Sea Foam® may cause the oil to become dirty faster than normal as buildup oil residue and contamination are cleaned. Check the oil at regular intervals and when it gets dirty, change it." |
Nautiquehunter
Eric are you saying the Lucas caused the sludge in the jeep? I remember the same thing when people used Quaker State oil in their car engines. If you dont let the engine run at operating temp long enough and shut it off it will also cause sludge.
anthonylizardi
Gold Member Joined: July-25-2007 Location: DFW, TX, USA Status: Offline Points: 836 |
I put on my oil on 99 Silverado, 177k miles. Now one of the lifter sounds when is cold. I had mix results with Seafoam. I think is decent to put on the gas.
good analogy, why would you take viagra if you can cut glass with it?
really though if you have a problem in an engine, fix the problem. we use alcohol to remove oil, i would really think the sea-foam would kill the lubricating quality of the oil.....fck, my nephew had to big of a carb on his engine and alot of the gas went into the crankcase, what a mess that made, all the pistons were scuffed |
The only thing I've ever added to oil is Marvel Mystery. I had rebuilt the little flat head engine in the Atom but then is sat for about 10 years. Flat heads are notorious for stuck valves due to their vertical position - all the oil runs away from the stem/guides. So, when I started it up, I had a couple stuck valves. Added the Marvel in the oil and gas and within several minutes, it was running great.
BTW, I also use 50% Marvel and 50% engine oil for fogging. |
peter1234
I only use it for small engines in the gas when i suspect it has float /bowl issues with the results (positive) i see from that i cant imagine using it in the oil.
Pete and I discussed sea-foam in another thread on fuel stablization. I mentioned the MSDS on this stuff showing the chemicals it contains. It also has Isopropyl alcohol(IPA) that adds to the ethanol already in our fuel.
Sea-foam was probably good back in the day with real gas and the older motors(or small 4-stroke engines) but with today's gas and motors I wouldn't want it in my gas or oil. |
skicat2001
Platinum Member Joined: November-24-2008 Location: Ft. Worth TX Status: Offline Points: 1950 |
I will say this, seafoam stinks to high heavan. I used stabil in 06,07,08. Somebody referenced me to use seafoam instead off stabil, and I ended up in 09 with carb problems non stop. I also used it because of 79 nautique said to someone else, pour it down the throat to ensure stabilty in the fuel system and off course after that, I had many carb issues left and right. Personally I think the issue was I always fill my tank full and then use the stabilizer to make sure of no condensation it took several years for it to get rid off in my tank. Shame on me for not flushing the fuel system but not think that seafoam would have caused this damage. Stay with stabil, it never has done me wrong.
1985 CC 2001-SOLD
Lee Michael Johnson |
BuffaloBFN
I have an '02 with similar miles that does the same thing. I had it professionally flushed but no fix. I wonder how long it will hold up like it is. It does get quiet after it's warmed up. |
