Another BFN Rebuild |
Post Reply | Page <1 2526272829 31> |
Author | |||
politicallycorrect
I hate to add to thread hijacks, but I like to speak up when I can. The earlier style fords had way more torque than the transmissions could handle. I'm not as versed on the internals as Eric but I don't know of many people that haven't replaced or rebuilt transmissions in those trucks. My father in law had to replace his in '86 twice before 200,000. Not sure if they offered a manual in 95 but it is the way to go with Ford diesels...or retrofit an allison .I've been told when towing especially in hilly terrain to shift up and down manually. The rest on those trucks is pretty bullet proof except for the water jacket around the cylinders tend to rust through. My dad had to sleeve his old 6.9 which is the same block as a 7.3. |
wakeboardin2k4
Platinum Member Joined: December-14-2006 Location: Hopatcong, NJ Status: Offline Points: 1117 |
It was the crank position sensor. What was actually happening was a power loss that felt and appeared like symptoms of a trans slip. In regards to the water jacket, a-men to that brotha! Except mine came through the side of the block. I am hoping this trans lasts. I had a trans shop take a look and they said it's fine. |
politicallycorrect
Crank sensor,*************** technology! Whole lot better than a new tranny though!!! |
Its been bugging me that I never brought this thread to completion... though I suppose the boat still isnt "done" so I guess I can keep adding updates.
We got the motorbox far enough along to be functional for the summer. The inside got reinforced, and then the corners were glassed: All trimmed afterwards: Then I went about adding the notch for the pylon. I cut the glass cylinder off to match the angle of the front of the box: Taped it in place, and then glassed it in. Then it was trimmed, and one final layer of glass was added around the outside. After that, it was trimmed flush and level... then simply installed. Those who saw it at GL may remember that it was still largely unfinished- but it did fit over the engine nicely. The plan is to put another coat of glass along the seam, grind it smooth, and then put a layer of white gel on both the inside and on the uncovered glass portion of the outside. Depending on how it looks, it may stay bare for a while, or it may get covered with vinyl eventually. The boat itself ran well initially- with the same Acme 1598 (13x14, .080 cup), the engine was able to turn ~5500 RPM with the EMI manifolds installed. Unfortunately, after a few laps around the lake, we found water in the oil- which we traced back to the fancy aluminum exhaust. For the next few weeks, we ran it with the older cast iron manifolds that came with the boat. Top end was down a touch (~5300 RPM), but the boat was good for a reliable 58.x MPH on the GPS, with several blips in the 59-60mph range. This included a decent 58.4mph showing at GL, good enough for a 2nd place finish behind Joe's mighty '83 (59.2mph). The fun was relatively short lived, however, as I overheated the boat running around in the lagoon near the camp ground. The strainer was *slightly* clogged: That resulted in a hydrolock, and another pair of toasted exhaust manifolds. Upon tearing it down, we found a broken lifter and a corresponding rough looking cam lobe- so the motor is currently back out of the boat and torn down as far as the cam. The most likely scenario is to give it another go with a flat tappet cam, unless we can find a RH roller for short money (not likely!). The good news is that we have some shiny new exhaust manifolds from Dana Marine that should hopefully get us back above 5500rpm come spring. The lake hasnt even frozen over yet, but only 3.5 months before it melts... come on spring! |
Bri892001
Tim, just curious, how did the overheat condition wind up resulting in a hydro-lock.
Did the overheat cause the exhaust manifolds to fail > which then allowed water in through the exhaust > which then caused the hydro-lock? |
Thats my best guess, yes. All cylinders had some water in them- and they would keep filling up after blowing the water out the spark plug holes. Compression test came back fine, and there were no signs of failure from the intake or head gaskets... so the exhausts were the culprit as far as we could tell.
Its worth noting that the cam failure and overheat dont appear to have been related... we simply discovered the lifter/cam issue when the engine was torn down. We're going to send the parts back to Comp to see if this is a failure that should be covered under warranty or not. |
M3Fan
Tim, thanks for the visual shout-out there. That was a fun ride.
What really struck me about this boat (and maybe this is just a standard BB thing) was just how casually the boat ran 40mph. My 351 definitely is "working" at 40+ mph, and this boat just loafed. The boat didn't really let on that it was doing ANY work at all until it got in the 50's. Love that! Even after 7 miles of it, the "casual" 40's cruising never got old. Seeing a pair of Airguides just slam into the pegs simultaneously is also quite a treat! |
i would bet that lifter had something to do with the water coming into the combustion chamber, I just sent a 25 hp kohler, (still related) to the engine family, it had a bent pushrod and the lifter was wiped, for the life of me i couldnt figure out how the pushrod bent, no marks on the piston, valve moved freely....but from what i gather, and the guy i use for machine work asked if my customer was squirting starter fluid down the throat and the answer was yes, he pin pointed it as being something to do with the cylinder cooling down and seizing the valve....beats the fck outame, sometimes you gotta put the torque wrench away and slam them together, those are the ones that run like raped apes.
out of curiosity, what hole did that lifter sit in? |
is the cam lobe wore like it took time or does it look like a fracture that happened quickly? id be really interested in the results from Comp, I swore them off years ago because of 2 cam failures in a week, most likely something i did, but they left a bad taste in my mouth, Ive used them since and have had no problems with the cams
Joel, youre right- it may be a big block thing. I know with the stock-ish sized prop (13x14 Acme) we ran, the engine is underturning by a good margin... somewhere in the 300-500 rpm range. With the bigger 750cfm carb, the secondaries dont come in until youre above 4000 RPM, which is approaching 45mph. The v-hull really shines on a big lake too.
Eric, the cam didnt look too bad- face of the lobe (where it contacts the lifter) looked pretty good. It was the edge that was beat up. My guess is that the lifter broke first, and the jagged edge tore the lobe up. I wouldnt think the handful of times that we spun the motor over after the overheat (it never ran- only cranked) could have done it... but I could be wrong. No signs of damage in the lifter bore, pushrods, or rockers. The offender was on cyl #7, I forget if it was I or E. |
BuffaloBFN
Tim, are those Advanced Marine valve covers? Got a pic of the top of that finished engine?
If it's still apart, check with Danny Griffin at Cam Motion about that RH roller cam. He offered one to me at ~$550. |
Greg, are you interested in the clearance to the manifolds with the valve covers? Im afraid I dont know the brand- but the ones I see on ebay look to be the same as what we've got.
$550 you say... I just put in a call to Cam Motion and the guy I spoke to said $750. Based on what he's saying, I believe he's the one who built the cores for Marine Kinetics. Their pricing is the same. I also called LSM Engineering and they can build one for about the same price. When did you talk to Danny Griffin? |
BuffaloBFN
I talked to him back at the first of this year. I may have the # wrong.
No pic? I wanted to see the hardware you chose on those VC's. 'Advanced Marine and Developement' |
The pricing seems consistent from one source to another, so hopefully Im not being taken for a ride! We havent pulled the trigger yet- currenly working with Cam Motion. I got the feeling that Marine Kinetics wasnt taking me seriously, and LSM stopped returning my emails.
Unfortunately, this is the best picture I have of the motor assembled. You'll have to be more specific on what "hardware" you want to see. We ordered our own VC bolts from McMaster. We bought our VC's used, so they already had the holes cut in them for the PCV and breather. We sourced grommets from Summit and Mcmaster. |
uk1979
Tim,Greg I have the rest of the chain RR cams awaiting shipping with some other parts,I have more than I need just could not let them go in the scrap bin.
Lets have a go
Roger, which cams are those? Im confused!
BuffaloBFN
Me too. Did we miss the story line? Roger, roller or FT? |
BuffaloBFN
Roger, I do think I remember you shopping marine speed shops?
Tim, my VC's are also used. I don't think they're made anymore. My question is about how you set it up assuming you have the same set up I got. My covers have 2 1.25" holes on one, and the other has one 1" hole. The originals had 1 larger hole on each side with a smaller addition hole for the PCV on one. In other words, I had an oil fill plug on each(same size) and the PCV. I can figure and fit everything, but I'm thinking they will look funny. |
Ahh, I see. Our "new" vc's are set up essentially the same as the originals in regards to plumbing. There is only one fill cap, located towards the front (high) stbd side. Not sure how large it is- its threaded right into the VC. Each one has a 1.25" hole right in the center (lengthwise), towards the top (middle of the engine), if that makes sense. The 2 grommets are different- one has an ID to match a PCV, the other is for the breather elbow. These holes were cut in the VC's before we got them, but they worked perfectly for us.
BuffaloBFN
Your covers are at least a little different than mine then. And I totally forgot about the elbow...duh. So I'll have 1 fill, 1 PCV, and 1 breather. I used 4" and 1" allen bolts for that part.
This is my OCD...didn't want 2 different size fill plugs...wouldn't have matched. |
I believe mine were probably blank at one point. The 2 holes (breather/PCV) sure look to be custom cut after the fact. The fill may have been there from whoever made them. Only one VC has a fill.
uk1979
Tim, Greg, These are the rest of NOS RR roller cams chain drive,I have done a deal with the guy to clear them up with some other parts I need. So if things don't work out with the gear drive cams I do have spare billet cams you could regrind to a lower lift as they are race/drag cams,that's if your happy to change over to chain drive and swap the distributor cog They are still in the US (New Jersey) looking to ship over to the UK in the next week or so. |
Lets have a go
BuffaloBFN
Nice find sir. My gear drive is fine for now, but one of those would be nice for next time.
Roger, very interesting! Ive yet to find someone who could confirm the existence of a true reverse rotation RH roller cam for a BBC (as opposed to the "standard rotation, reverse firing order" gear drives like we have). I know they exist for the SBC's, as Joe has one in his 383.
I guess Im good with my gear drive set up for now- but I wouldnt mind having one of those on the shelf either! Im curious how much they can be reground though- isnt there a limit to such things based on surface finish/heat treat? |
Not coming from any direct cam experience mind you, but I would expect that the case hardness is a bit less of an issue with a roller lifter on a steel cam blank than it is with a flat tappet on a cast blank... I never seem to know what is going on with roger these days sounds like a florida sit down is in order.
uk 1979 part2
Groupie Joined: April-30-2011 Location: UK Status: Offline Points: 71 |
Tim, they are like the ones I have here that I have shown you Crane Billet, unlike cam blanks that are hardened then ground to size, Billet are cut/ground to rough profile then hardened and final polished giving much more that can be reground, Crane Billets are generally good for 2/3 grinds depending on spec. He has thrown in the matching LH Billet cams he has left, not so many as they have been reground for other builds, It’s my understanding gen 5/6 BBC RR engine are chain drive as the RR Vortec SBC. Looking forward to Florida Joe and catching up with the 83 latest build. |
lets have a go 2
Good info Roger- I assume Gen 5 and Gen 6 cams interchange with Mark IV's?
Will be good to finally meet you next month! |
uk 1979 part2
You have to tweak the cam retaining plate I believe and run after market roller lifters not OEM in older BBC. Will be great to meet you too... Billy and Karen are the best hosts and catch up with the SJRR family. |
lets have a go 2
I suppose its time for this thread's yearly update... and hopefully the last!
After thinking it over all winter, this spring we decided to go forward with the most reliable (and most expensive, ha) option- custom RH roller cam conversion. The goal was to not tear this engine apart again anytime soon! We worked with Bob Madera at Marine Kinetics (Rochester, NY) on the grind specs and ended up with a wilder cam than before. Due to our engine's high-ish compression ratio, it was decided to go with a longer duration in order to keep cylinder pressures down (and thus avoiding damage causing detonation). Combined with the roller's steeper ramp rates, it allowed the lift to be over .600. Output was projected to be in the ~480hp @ 5600 range. Of course, in order to use the roller cam, we added tie bar roller lifters. The more aggressive profile required upgraded (Isky) valve springs as well. When measuring our heads to see if our valves would work with the new springs, we discovered that the water ingestion from last year's overheat had left a good amount of corrosion around the valve seats... so off came the heads for a full valve job. Went with +.100 Ferrea valves (SS 6000 series intake, Super Alloy- similar to inconel to withstand higher temps- exhaust) on the rebuild. Custom Manton (Series 4 for guideplate use, 3/8" diam, .120 wall) pushrods rounded out the changes. We fired it for the first time the Friday of the CT mini reunion and promptly put it in the water. Only a few minor glitches thus far (leaky valve covers, wicked dirty neutral on the tranny, leaky secondary bowl after shut down), but the oil has stayed clean and we havent blown it up yet... so Im declaring victory. Dad and I took our first double barefoot run behind it that first day (Im hoping someone has a picture?) Pic (thanks Morfoot and Chris) and a quick video (thanks Brian) from that weekend: (Secondary spring needs to be stiffened up... it was right on the verge with that load in the video, hence the in/out.) So far, performance has been every bit as good as we had hoped for. We still havent found a prop that we cant cavitate in the midrange. Here's what we've run thus far: Acme 1598 (13x14 3-blade): 62.8mph @ 5700rpm Acme 430 (13x13 3-blade): 61.9mph @ 6000rpm Acme 1868 (12.5x14.25 4-blade): 56.4mph @ 5500rpm Acme 612 (12.5x15.25 3-blade): 61.7mph @ 5500rpm So far, I like the 612 the best, as the boat seems to cavitate a little less with it. I expect it to speed up a bit with a full tank of gas and a little weight in back as well (which were the conditions the 1598 and 430 were run under)... I dont see why it wouldnt be the fastest prop of the bunch based on the RPM's its running. The 1868, on the other hand, pushes the nose down HARD in the low 50's, which explains its lower top end numbers. All of the props do this to some extent (as do many of the other faster CC's, like Joe's '83, so I think its partially attributed to the steep strut angle), but this prop does it earlier and harder than the others. It appears to be a different style of prop than the Acmes Im used to seeing (its much flatter, so I may refer to it in the future as a "pancake" prop). This is the stock prop on the Excalibur powered SN 200's, so its stern-lifting abilities may have been a positive on a slalom dedicated tug like that. I may still try the 1442 (13x15 3-blade) and 422 (12.5x15.5 4-blade) on the boat, as it doesnt seem to have any problem pulling the larger wheels out of the hole... its more a battle of being judicious with the throttle to keep the cavitation in check. It will hold ~2800rpm for a split second and then get up to 5k as the boat continues to gain speed. Sort of like a snowmobile... but I think it would be a lot quicker if we could find a prop that hooked up. |
wakeboardin2k4
No stainless steel 2blade prop runs just to see how it compares?
