$600 (+-) Oil Change |
Post Reply | Page <12 |
Author | ||||
and don't do anything that will give you rash
75 Tique
Grand Poobah Joined: August-12-2004 Location: Seven Lakes, NC Status: Offline Points: 6109 |
Wow!! if that tool with the bolts in it didnt do it, that sucker must be welded on there. Can't be too careful, don't want them spinning off while your heading down the lake.
quinner
Righty Tighty Lefty Lucy
Dreaming
from the way your bolts are bent, this may be timely advice anotherthought...if you could get a 90 degree angle pick between the filter seal and the flange, you could run some oil down the shaft of the pick, and onto the filter seal... do this in several locations to help unglue the seal from the motor? |
84 BFN
Newbie Joined: August-02-2007 Location: United States Status: Offline Points: 22 |
I’m spinning it counter clockwise – toward the front seat (left) or toward the front of the engine.
Man, after a while I started doubting the direction, so I used a 1/2” PVC fitting with the new filter to confirm. I talked to Bull and said to use brute force to get it off. So I plan on working from the holes in the oil filter base with a small cold chisel and start prying but staying away from the block. There is an insert in the block that could get damaged if I go completely nuts, but he said it can be replaced. I’ll let you know what happens. |
84 BFN
Longwood, Florida |
lakedog55
Since everyone else has chimed in. Line slip joint pliers up with the holes Tap them in with a hammer and turn the correct way and it will spin right out.
Mike |
Lakedog55
harriss28
Senior Member Joined: July-24-2010 Location: Titusville PA Status: Offline Points: 128 |
With proper precaution, a nut can be tacked on, no problems. |
Shawn, Could you detail the precaution(s) needed? |
mark c
That sounds like its clockwise, which is correct. Guess its all in your point of view, looking down from the top clockwise loosens it, looking up from below clockwise tightens it). Oil filter is on the left side of the engine, if you put a wrench on the filter with the handle sticking out to the left and pull the handle towards the bow (rotating clockwise), thats will loosen the filter, if you pull the handle towards the stern that would be tightening the filter (rotating counterclockwise). |
harriss28
cover work area, get some wet rags to extinguish possible flame...done |
I know a guy who's shop burnt down due to weld spark that landed in the wrong place. I would save this option as a 2nd to last resort. Pulling engine is last.
Shawn,
Thanks for filling me in on the precautions needed for welding. I need to ask, in your line of work, do you ever need to "pull" a "hot work" permit for welding or cutting per OSHA? |
I would weld that sucker with nothing but some fans, a few leathers, and some wet rags and not worry about it one bit.
I dont know a chevy from chrysler but on a ford the insert that the filter is screwed onto has a large allen socket in the middle if the chevy is the same way I would get me a good well fitting tool in that and put the insert and what is left of the filter off. But I would be sure of the direction it is threaded in before doing so… as it might not be soo righty tighty lefty loosey to keep it from coming out with the filter. |
mark c
Big block (and small block) Chevies made after 1967 have bolt on oil filter adapters attached to the block with 5/16" bolts.
After you get the filter off, remove it and get a remote oil filter adapter and move the filter to a more accessible location. |
84 BFN
I got it off. I followed Bulls advice and used brute force. I used a punch and bent the base ever so slightly and then I use the modified tool to spin the base off (counter clock wise or spinning toward the seats). What a relief! Now I can go skiing!! It would have been a drag to pull the engine just for the oil filter and then have to pull it again for the stringer project early next year.
Thanks for the help! |
84 BFN
Longwood, Florida |
That gasket sure looks dry. Plus, I have a feeling that filter was over tightened.
I'll bet a Fram would have come off easier due to their construction
64stang
Newbie Joined: June-25-2012 Location: Wisconsin Status: Offline Points: 38 |
I like Fram as well, but that was a Purelator Premium filter, not really a junk filter by any means. I think too tight along with no oil on seal was the cause.
Why? After reading all the tech reports on the junk Fram!!! BTW, Gary was being factious. Sorry you didn't pick up on that even though he added all the emoticons!! |
64stang
I should have cought the emotocons, actually I ignore them. I like Fram because of the grippy surface and usually use the better ones. The grippy surfacde allows me to put it on by hand and not worry about using a wrench. Some filters are so smooth that I can't grip them and end up using a tool, thus they may end up too tight. But I did sell auto/truck filters for a while and had some training on them and actually all have a pressure release spring that allows oil to bypass the filter during extreme conditions, like hard accelleration. That being said, too much filtration causes the bypass to activate more often. A good quality filter changed frequently enough provides more than adequate protection.
By the way, thanks for all the help with my boat. Mark |
Bri892001
Wow, must have felt awesome when that thing finally came loose.
