Bolt replacement ! S.S. or not? |
Pete LHC
Newbie Joined: July-30-2006 Location: United States Status: Offline Points: 8 |
Posted: September-02-2006 at 1:17pm |
I just want to say thanks to everyone for their input...this is a great site.....
supported by great people. |
Thanks,
Pete |
jimbo
Senior Member Joined: September-07-2004 Location: United States Status: Offline Points: 473 |
A good read. Thanks. Some people like to read Stephen King, some like Tom Clancy. I love reading that kinda of stuff
rmcdonald
Groupie Joined: December-30-2005 Location: Australia Status: Offline Points: 71 |
Hi
Here is a good link discusses and gives a reference matrix for combining dissimmilar metals. It is mainly concerned constant under water exposure between dissimialar metals. Stainless steel fasteners Regards Rob |
Man you are just out there in lala land all of the time John maybe its all of them diesel fumes you inhail.
john33617
Senior Member Joined: July-07-2004 Status: Offline Points: 182 |
never use SS bolts on exhaust manifolds , they expand at different rates and will break the manifold
jimbo
Hey, thanks 91
91nautique
Senior Member Joined: May-26-2005 Status: Offline Points: 104 |
Jimbo.
Does this help? Arranegment of metals in galvanic series CORRODED END (ANODIC OR LESS NOBLE) magnesium zinc aluminum cadmium Any of these metals will theoretically steel corrode while offering protection to lead to any other that is higher in the series tin so long as they are both electrically nickel connected. bra$$ bronze copper nickel-coppper alloys stainless silver gold platinum PROTECTED END (CATHODIC OR MOST NOBLE) Ive got an anod on the exhaust outlet of my boat,its wired internaly with S/S wire to the lift rings and onto the aluminium bracket that retains the steering cable,up and onto the motor so that it covers the shaft and prop. In salt water,parked up next to the houseboat with aluminium pontoons, the anod will last about three months. Fresh water it hardly wears at all. Great forum, thanks for all the ideas ive managed to "steal" from you guys over the years. |
jimbo
That's what I figured. The only freshwater boats that need them are the ones with a big hunk of aluiminum hanging off the a$$-end. I'm just not a good enough inorganic chemist to know what other metals are incompatable with steel. |
the I/O's have more aluminum in them that reacts with the steel creating electrolosis thus the need for anoids
jimbo
Use cap bolts and anti-sieze for sure.
They have a smaller head than other bolts of the same thread diameter. I've been replacing my bolts with with kinda goldish bolts from the local hardware store. I think they are grade 8. Probably overkill on the strength side but they seem to have good rust resistance. Now, even though I have a background in Chemistry, I just don't fully understand this... On I/O boats, like Mercurys, they put these zinc anodes on the lower unit -- sacrifical anodes. Something about two dissimuliar metals and electro-chemistry. Anyway, our boats don't need the anodes but I'm always wondering if the bolt, or pin or what ever I substitute is going to cause a problem. Does anybody know what metals put together require the anodes? I think Aluminium is one. Does anybody know? |
Rick
Senior Member Joined: March-03-2004 Location: United States Status: Offline Points: 338 |
i agree with Tim D I would use regular manifold bolts with antiseize compound.
Yup, No surprise 316 will gall, 316 is for high purity plumbing; for bolts its gall-o-matic.
Its best purpose is inside process chambers; its quite misused elsewhere. |
64 Skier
Senior Member Joined: February-08-2004 Location: United States Status: Offline Points: 415 |
ARP is the only way to go. Their Stainless Spec is chromemoly 8740 (Grade 8 plus) or something thereabouts which is way better than 304, 316's etc.
JEFF KOSTIS
Gold Member Joined: April-19-2005 Location: United States Status: Offline Points: 817 |
Stainless bolts are great for "light duty" applications, but dont work well for future removal as they "gall" and snap off. Most stores sell 304 stainless bolts which are equivelent to a grade 2 standard bolt (no dashes on head). You can order and get 316 stainless bolts equivelent to a grade 5 bolt (3 dashes). Anything harder is more difficult to get. Even the 316 stainless will gall over standard bolts if overtightened.
A grade 8 bolt (of whatever head you need) offers better rust resistance and strength and would be my choice. My .02 good luck!! Jeff... |
They will work but over the long haul caps screw are better and are easier to get off the next time the heads won's shrink as much they doen't get rounded off it provides more clearance as well and won't dig into the manifolds as much either.
Tim D
Regular bolts should be just fine, just put a dab of anit-seize on them.
Tim D
Pete LHC
My bad...I stand corrected....They are not headers.....just manifolds......
Thanks,
Pete |
depends if you like your bolts to rust off or not.
Where did you get the headers? extremely rare for a 351W to have headers most like they are just manifolds. I would suggest using socket head caps screws over standard hex head fasteners. |
Pete LHC
I am in the process of replacing the exhaust
headers on my 80 SN. Is there any reason NOT to use Stainless Steel bolts as replacement? |
Thanks,
Pete |
