If you have a Barracuda |
skyfuzz
Senior Member Joined: August-17-2004 Location: South Florida Status: Offline Points: 239 |
Posted: August-25-2015 at 10:05pm |
Any one that has a Barracuda, please let me know the measurement between the floor to the bottom(keel) just forward of the engine where a ski pylon would go. When you have the chance. Thanks!
http://www.correctcraftfan.com/diaries/details.asp?ID=7613&sort=&pagenum=1
Robert,
I'm curious as to why you need this measurement. If it's for a sole attachment plate on a pylon, you don't need it. The pylons in the Cuda's were attached at the keel only then they just went through a reinforced hole in the sole. |
fanofccfan
Platinum Member Joined: December-13-2009 Location: North Bend NE Status: Offline Points: 1745 |
I assume the same mounti on my marauder as well Pete...... Correct?
skyfuzz
If the keel to floor measurement is 10" in a Wildcat and the motor box is an additional 27", I would need perhaps another 4" or so for clearance above the motor box, so I would need a pylon that is about 41"-42". I'm looking to buy one out of a Cuda, I was told that measures 36" from floor to top of ring. I'm just not sure if there is more length of said pylon down below the floor to the keel. If there is another 5"-6" I can get this pylon. I am not near the Cuda and relying on what sellers wife measured. |
93/70 ccpb
Senior Member Joined: March-05-2006 Location: United States Status: Offline Points: 448 |
i will measure tonite when i get home.i have a 69 cuda ss
skyfuzz
Thanks, I will be awaiting your answer. |
93/70 ccpb
8 inches from bottom to top of floor..brass sleeve that pylon goes into is about an inch off bottom . hope this helps.what did you ever do with the gray marine engine?how were the exhaust manifolds?carb/2BRL OR 4 BRL.
skyfuzz
Thank you so much for that info! I don't know what the shop has done with the Gray. I will email and ask. As far as I know, the mani's were okay and I think it was a 2 bbl.
