  New Posts New Posts RSS Feed - Mustang 17 rebuild
Mustang 17 rebuild
 Post Reply Post Reply Page   123 5>
Duane in Indy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane in Indy Quote  Post ReplyReply Direct Link To This Post Topic: Mustang 17 rebuild
    Posted: January-24-2016 at 3:32pm
I have finally finished up the stringer and floor replacement job in my '78 Mustang. Not ready to do another one of these for a while. Will be building seat frames next. Re-gel top and bottom and then it will be on to updating and freshening the engine. Last pic is of the other "Mustang" I work on a 1979.
        1978 Mustang (modified)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane in Indy Quote  Post ReplyReply Direct Link To This Post Posted: January-28-2016 at 3:14pm
Front seat frame is fabricated all but the aluminum sheets for the upholstery to go onto. I will weld them into place and then clean up the weldment. Used 1 X 1 X 1/8 wall aluminum tubing. Hope to have rear seat frame done Friday and then deliver to upholstery guy Saturday. MUCH lighter than the original. Opted for a full front seat instead of 3/4 because it will fit our needs better. More pics to come. Duane
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: January-28-2016 at 4:47pm
Duane,
Nice fab job. keep the pictures coming.
Chevy350 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chevy350 Quote  Post ReplyReply Direct Link To This Post Posted: January-28-2016 at 10:10pm
Seeing this makes me want to get my dad and I to redo the floor on our mustang.
1972 Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane in Indy Quote  Post ReplyReply Direct Link To This Post Posted: February-04-2016 at 3:15pm
Heading to upholstery shop with the front seat. Pics show frame only and frame with rigid backup foam. Original foam to go back in..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane in Indy Quote  Post ReplyReply Direct Link To This Post Posted: February-05-2016 at 6:07pm
Was busy today punching holes in the rear seat back. Punched over 200   1 5/16 dia. holes Trying to keep everything as light as possible without compromising strength. Will try to do the seat bottom tomorrow. The back seat bottom will hinge forward so as to access rear bilge area. The seat back "keyholes" in on some pins. Ordered upholstery material yesterday. Blue.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane in Indy Quote  Post ReplyReply Direct Link To This Post Posted: February-21-2016 at 3:23pm
Been busy since dropping stuff off to the upholstery shop. Fabbed up an engine cradle. The original setup was nothing more that a chunk of 2 X 4 cut on a 15 degree angle and lag screwed to the stringers. This set up will get cross bolted and lagged to the stringers. I will bed the cradle to the stringers with thickened epoxy prior to bolting down. Going to glass bead my mounts also. Should be a lot stronger and will spread the load out.
Orlando76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: February-21-2016 at 3:37pm
I like the cradle. Why not fab it up to brace the pylon too, wouldn't be much more effort?
1976 Ski Nautique 351 Escort
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane in Indy Quote  Post ReplyReply Direct Link To This Post Posted: February-21-2016 at 3:56pm
Pylon mount already in place under floor. Bedded in and bolted down and in socket in hull
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane in Indy Quote  Post ReplyReply Direct Link To This Post Posted: February-21-2016 at 4:03pm
Finished shot of pylon
LeftFieldEngineering View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeftFieldEngineering Quote  Post ReplyReply Direct Link To This Post Posted: February-21-2016 at 5:15pm
Love the fab work,
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: February-22-2016 at 12:43am
Wish I could weld like that.
Nice work!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane in Indy Quote  Post ReplyReply Direct Link To This Post Posted: February-24-2016 at 2:42pm
Been busy making wood shavings instead of metal for a change. Made my new dash panel from some Poplar that I've had in the loft to 25+ years. Planed it down and then put it on the mill. Stain, acrylic urethane, sand and buff. Glove box cover is not sanded or buffed yet. Wiring will start soon.
Fabcon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fabcon Quote  Post ReplyReply Direct Link To This Post Posted: February-24-2016 at 9:53pm
Very nice fab work.
1984 Barefoot Nautique (Parting Out)
Kristof View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kristof Quote  Post ReplyReply Direct Link To This Post Posted: February-26-2016 at 10:18am
That is some nice craftsmanship!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane in Indy Quote  Post ReplyReply Direct Link To This Post Posted: February-26-2016 at 2:41pm
Thanks for the compliments.
tryathlete View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tryathlete Quote  Post ReplyReply Direct Link To This Post Posted: February-26-2016 at 6:18pm
That's some sweet aluminum welding partner. I'd be more specific but I know what happens when I use language like filet weld and butt weld.... Quinner has some sort of alarm system that goes off and, well.... You know what I mean.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fanofccfan Quote  Post ReplyReply Direct Link To This Post Posted: February-26-2016 at 10:47pm
Nice work. Both the metal and dare I say it? Wood.....works!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-26-2016 at 10:50pm
Great looking work Duane.
backfoot100 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote backfoot100 Quote  Post ReplyReply Direct Link To This Post Posted: February-27-2016 at 8:55am
DAYAM!!!!! That's some nice work. Very sweet.
Eddie
Smithfamily View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smithfamily Quote  Post ReplyReply Direct Link To This Post Posted: February-27-2016 at 9:24am
Very impressive! When we gonna have her in the water? Summer is approaching!!
Js
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morfoot Quote  Post ReplyReply Direct Link To This Post Posted: February-27-2016 at 10:11am
Looks like maybe I shoulda took another couple of years of woodshop back in High School. Beeeeeeeeeeeautiful! Nice Persian rug too!
On a second note.....I was looking at the stern pictures a little closer at the top of this thread and noticed the OEM air ducts back there. I replaced mine with flexible RV waste line I got at Walmart. It's basically the same stuff that's in there just black. Copper wire reinforced and TOUGH Vinyl.. It was a chore getting it on the scoops but I won the battle. Mine was mildewed real bad and dry rotted just as bad.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-27-2016 at 11:11am
Yes but one think they wouldn't have taught is how to use a insert fly cutter in a vertical mill (Bridgeport) on wood!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane in Indy Quote  Post ReplyReply Direct Link To This Post Posted: February-27-2016 at 11:36am
Pete, You have a clever eye. Also when we were in wood shop they had not invented the insert carbide cutter yet!! As I had told you in a PM, that I also built that insert cutter years ago. Bridgeports and wood don't really go together, do they? LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane in Indy Quote  Post ReplyReply Direct Link To This Post Posted: February-27-2016 at 11:42am
I made a note of your suggestion on RV hose at Walmart when you first posted it and even went there to check it out. Found two thicknesses of hose. Thanks for the suggestion and big thanks to you and all others for compliments.
Rebuilding these old boats is like eating an elephant, one bite at a time and you'll get there
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-27-2016 at 12:01pm
You must be a couple years older than I since I remember the inserts were just coming out. Back then, we would have had to been creative at the tool grinder and use one of these:
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCH20SKIER Quote  Post ReplyReply Direct Link To This Post Posted: February-27-2016 at 1:22pm
When I was doing the Chris Craft Wenfound some ducting the local race teams (nascar) use to cool the breaks - if I recall it was 3" black and pretty stout (yet flexible). Spendy though when it is sold by the foot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: February-27-2016 at 2:32pm
There's a reason Correct Craft used dryer vent,when you say boat,airplane or racecar you know what that does to the price
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane in Indy Quote  Post ReplyReply Direct Link To This Post Posted: March-12-2016 at 2:06pm
Interior is all at the upholstery shop so I started working on the engine some. Went with FLOTEK heads. They are a really nice piece. Very little core shift. I have port matched them and did a mild port and polish job. For the money they are hard to beat plus you save about 40 pounds over stock heads. They can even be painted blue to suit the original folks..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane in Indy Quote  Post ReplyReply Direct Link To This Post Posted: March-13-2016 at 6:54pm
Port matched and opened up the exhaust manifolds/heat exchangers. The ports were really restricted. Have to be careful not to thin the walls too much. First pic shows how small the port really is. Second pic is opened up considerably, the shadow in the rear makes it look like a big restriction in there but is only a shadow
