01 Ski Nautique Engine Trouble |
Mpc89
Newbie Joined: March-31-2015 Location: Winter Haven,FL Status: Offline Points: 6 |
Posted: March-16-2016 at 5:43pm |
Ok Guys, Just got the 01 SN out of storage it sat up for the past 4 months and ran her. It ran for an hour then started sputtin and spattering and died. Tried to restart but to no avail. It would fire for half a second but couldn't ever get it started again. I took the fuel filter off and inspected it but it was clean. i reinstalled the filter and primed it back up and she fired right up, so i dumped her right back in the water and she ran great for an hour and then pulled her out. I put her back in today (the next day) and she ran great for a couple of minutes then died out again and couldn't restart. Any ideas?
quinner
Stale gas, add 5 gals of ethanol free or premium and see how it goes, maybe even some seafoam if the fuel was not treated
Mpc89
just took off the fuel cartridge again and there was hardly any gas in the bottom. I tried to start again with the cartridge off and i caught the fuel in the cartridge and reinstalled and she fired right up. any ideas
Mpc89
how can i check the fuel pump?
quinner
What is it, GT-40?? Low pressure fuel pump or I believe there is a relay also??
Pump relays come up often as a problem.
Mpc89
Yeas t's a gt-40
NCH20SKIER
Check the small hose within the canister - had a similar issue to find the hose in the FCC had a crack about 3/8 of an inch long
'88 BFN |
tryathlete
On many GT-40's it seems fixes to your exact problem surround the low pressure fuel pump. It wasn't until I replaced mine, that the stall and no restart went away.
Just for grins, if it stalls and won't start.....try keeping the ignition switch engaging the starter for a few extra seconds. Not a fix, but will get you going again until you replace the LPP. There are a few "cheaper" things to rule out like relays and kill switch, and the anti-siphon valve on the gas tank, all can cause similar problem. If you read the Poor Man's GT-40 Troubleshooting guide on this site, you'll see wome of what is talking about. |
Poor man's troubleshooting |
Mpc89
Thanks guys! Gonna start with the relays and see. I appreciate all the help! Thanks Again! Mike
