  New Posts New Posts RSS Feed - Paint for the dash?
Paint for the dash?
797nautiqe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 797nautiqe Quote  Post ReplyReply Direct Link To This Post Topic: Paint for the dash?
    Posted: May-05-2016 at 12:02pm
I want /need to re paint my dash on my 75 sn. I was hoping some one can direct me want paint to use and the best way to remove the windshield when i do it. Thanks Tony
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: May-05-2016 at 12:05pm
It's gelcoat, just buff it out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 797nautiqe Quote  Post ReplyReply Direct Link To This Post Posted: May-05-2016 at 12:07pm
It was painted black before I bought it or it that original?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: May-05-2016 at 12:10pm
I suppose someone could have painted over the original black gelcoat...
phatsat67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: May-05-2016 at 12:10pm
Not original. The dash color change to the deck should me smooth without a bump. Paint was never an option.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 797nautiqe Quote  Post ReplyReply Direct Link To This Post Posted: May-05-2016 at 12:13pm
Ok so if I remove the windshield I'll know for sure correct?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: May-05-2016 at 12:15pm
Actually, 1975 was the one year CC painted the dash black. They matched the rest of the deck through '74 and were gelled black starting in '76.
I don't have any paint recommendations though. I'd be tempted to strip the existing paint and see how the gel looks before committing to repainting it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 797nautiqe Quote  Post ReplyReply Direct Link To This Post Posted: May-05-2016 at 12:17pm
What would you use to strip the paint off without harming the gel coat?
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: May-05-2016 at 12:18pm
Hmm good info there Timmy. I dig the non black dash boats.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: May-05-2016 at 12:38pm
I personally have never found a paint stripper that was safe to use. Many will say safe for fiberglass,and Corvette forums will recommend certain ones. I have tried them and while safe for fiberglass they do in fact dissolve gel coat. Best way for me has been ,while tedious,is sanding
Post Options Post Options   Thanks (0) Thanks(0)   Quote 797nautiqe Quote  Post ReplyReply Direct Link To This Post Posted: May-05-2016 at 12:40pm
What about easy off oven cleaner?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: May-05-2016 at 12:41pm
The non-safe ones can be used if you're careful. Just work in small areas and don't let it sit too long. Probably will be some sanding involved near the end.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 797nautiqe Quote  Post ReplyReply Direct Link To This Post Posted: May-05-2016 at 12:56pm
Ok thanks! Does anyone have experience with removing the windshield?
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: May-05-2016 at 2:01pm
Under each front section you'll find 3 bolts per each, 6 total across the front. Each side glass will have 2.   Nut is 3/8" or maybe 11/32".     If you are a lucky person, all 10 nuts will come off.    Otherwise you will probably break all the bolts.
Paint - Rustoleum Satin Black
New Seal - Camper Seal foam seal tape.
New T-Bolts - There are some other threads in here that may have some info on where to find t-bolts.
Other - Have a helper, and lift straight up. and be careful. also, while it's off would be a great time to inspect and tighten all other screws in the windshield frame.
Orlando76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: May-05-2016 at 2:53pm
The finish on the 75 and early 76 always intrigued me. Where'd the texture come from?
1976 Ski Nautique 351 Escort
shierh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shierh Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2016 at 2:44pm
i painted mine with PPG Essentials, grey.   left orange peel on purpose.
OldBrewer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OldBrewer Quote  Post ReplyReply Direct Link To This Post Posted: May-18-2016 at 7:03pm
I used toilet bowl bolts from ace hardware part #46744, you need 5 packs. They are brass T-bolts with washers and nuts, throw the washers and nuts away they look like stainless but are not. While your there get your self some SS 1/4 x 20 locking nuts and fender washers. Also they have rubber washers next to the T-bolts part # 40202 you need 3 packs. a note on the T-bolts they are 1/4 x 20 and 2-1/4 long, the heads are a little oval and will have to be ground down also the threads on the sides till they fit in the slot.
