Mustang 17 rebuild |
Post Reply | Page <12345> |
Duane in Indy
Getting ready to shoot the port side. Masked off finally. Prep work takes much longer than actually painting. Word of advice for those wanting to have a sign shop make their masks: have them make them in a contrasting color. Nearly impossible to see the font with white mask on white hull. Live and learn! (Learn means " I'm not doing another one of these!!!)
Hard to see the Mustang lettering You can see what I mean with the number mask |
1978 Mustang (modified) |
NCH20SKIER
Nice work.
'88 BFN |
Kristof
Very nice indeed!
Duane in Indy
Productive day. Painted stripes and lettering on port side today. That should wrap up the paint work. Give it some time to harden out and I can wet sand and finish buff the hull sides and bottom. BTW I have the font graphics on file if anybody else needs them. Any sign shop should be able to convert them to their file type. Not perfect but very close to original.
First "tack" coat shot Painted and masks pulled |
I like it! Fantastic Duane.
Duane in Indy
Thanks for the kind words!! Hope to flip it back onto it's feet soon. Hope the Reunion listings will start showing up so I can plan on attending some events. Duane
JPASS
That came out awesome.
Nice job |
'92 Correctcraft Ski Nautique
crabman
Senior Member Joined: March-05-2013 Location: Three Rivers Status: Offline Points: 216 |
Awesome Job so far!
https://youtube.com/shorts/D6xrs4xlDVY?si=uOaaduvSAlFcLOAU
swilliams
Senior Member Joined: June-26-2016 Location: Cincinnati,Ohio Status: Offline Points: 235 |
Awesome! How about doing a Martinique in Cincy?LOL..seriously that is very nice!
Nice job Duane! Hope to see it in person someday
Alex47
Senior Member Joined: November-11-2010 Location: Tarzana Status: Offline Points: 136 |
WOW!
Duane in Indy
Well back on the hull again. Flipped it back on it's feet again. Prepped the deck and shot the gel coat. Hopefully that is the last of the gel to shoot. Ground out a lot of stress cracks and filled them in along with numerous screw holes that are no longer needed. Give it a few days to cure out and then wet sand and buff. Appointment with the interior guy to lay the carpet in a week. Busy week in store.
Prepped and ready Gel shot I stripped the vinyl off the 3 scoops and they are in such good shape I a considering shooting a quick coat of gel on them instead of recovering. They could be used as is except the color might be off a bit. |
Duane in Indy
Sneak preview of what's been going on with the Mustang project. More to come after the sanding and final buff.
If I leave the scoop gelled then I will carry the stripe thru. Otherwise may cover it back with vinyl. (which is the same color as stripe) Thoughts???? |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10734 |
Hi Duane
How about solid blue gelled scoops front and rear? I think that would look good, but then I'm not looking at it in person Aren't there lotsa screw holes in those scoops? I don't remember.. |
NCH20SKIER
I vote for the recover of the scoop
'88 BFN |
JPASS
I say leave it gelled with the stripe going through it.
Duane in Indy
Well 15 months from the time I pulled the engine till it sits back on the mounts today. Did not even take time to clean out my tools and mess before I took a pic. Lots of work yet ahead but light at the end of the tunnel now. Will post more as I clean up the mess and start buttoning it up. Wiring is all run and just a few wires to hook up on the engine. Wiring was a big concern but it went well. 100% rewired. . Duane
Duane in Indy
Almost 16 months since she was in the water. New stringers, gel coat, floors, no foam except underside of bow cap, new .060 engine with many mods. Anyway made it to the lake today and lake conditions were terrible. White caps 3 feet high. Launched and finally found some decent water. Running an ACME 540 prop. Have a 5400 RPM rev limiter chip in the MSD box. Made a few passes to get a feel and then made several aggressive passes. I have a set of manually adjustable trim tabs that I will photo in the morning that were set flat, with no trim added. Boat porpoised some at around 45 - 48 mph. Not bad but noticeable. It easily drove thru them and at 5200 RPM was showing 56 MPH on first pass. Return pass was up to almost 60 MPH. Acceleration was unbelievable compared to the stock engine. Never did let the boat run on out since the engine has such low hours and the 5400 chip. Really don't want to exceed 5400 anyway. I will put a little trim in it and try some more. I can see where more prop would help or just live with what I have and not push the envelope.
Now the bad: Lost reverse somehow. Will trouble shoot that tomorrow and see where that leads. 1200 hours on the tranny so it may get a total rebuild. Temps and pressures were right where I want them on the engine. More later, Duane FloTek heads must be doing their job!! |
Way to go it's got to be a great feeling Duane. Now you know what they say "Pictures or it didn't happen"
tryathlete
Nice to have some power on tap for when three or four friends all want to barefoot at once! 60 mph. Dang. Wait until she's broken in.
Reverse. Yeah. Time for some rebuilt action. Better now and DIY than mid-season. I'm really impressed with your craftsmanship, Duane. How do any of you get rid of that bounce without risking planting the nose? |
81nautique
Grand Poobah Joined: September-03-2005 Location: Big Rock, Il Status: Offline Points: 5774 |
Looking forward to seeing and taking a ride in this boat at lakes James in July.
Duane in Indy
Few more shots of the rebuild. Still have a floor panel to install along with the engine cover. Lot's of finish work to do and also the final buff and polish on the new gel and graphics. Now the first order of business is to figure out the tranny issue. Sounds like I will be rebuilding it. Might as well as everything else in the boat is new.
Duane in Indy
Carb is setting perfectly flat now. Milled the intake manifold as much as the casting would allow and then machined a wedge spacer to make it level. Quite a bit of wedge added to achieve getting it where I wanted it.
Duane in Indy
More Mustang 17 shots. Rear shot show the trim tabs and the 3 1/2" exhaust turn downs. They have flappers built into them also. Built them here at my shop.
ps. gathering parts for the new trailer also. |
Duane in Indy
These are the manually adjustable tabs. Milled pockets in the hull so they sit flush when not deployed and will create no drag. They are attached at the front and you just loosen the wing nuts and move the rear down and relock. They are approx 6 inches square. May never use them but they are there to play with. Exhaust flapper is visible also.
Sounds strong Duane, but how were you measuring speed? A stock 540 isn't going to overturn much, if any- it'll run darn close to 1:1 speed vs rpm. I can't fathom how you'd get 60 if you're only turning 5400.
Also, be very careful with those tabs- at higher rates of speed, keeping the nose high is an important safety concern... if it porpoises then you're in the safe zone. Forcing the nose down can cause very dangerous behavior. |
SWANY
Very impressive. My hats off to you
Duane in Indy
Used the AP on my phone. Strong winds so not sure how accurate because I didn't do back to back opposite direction runs Even yet it runs very good. Acceleration is awesome compared to the boat before rework. Prop bought used and the previous owner said he had it worked on and didn't like it so I bought it. The tranny is original and I should have rebuilt it while the boat was down. Lost reverse. Just trying to gather as much info as I can so I can tackle the rebuild. Any suggestions are appreciated. Duane |
Bummer on the tranny. Bring a real GPS along next time, or download the Navionics app, that has proven to be accurate.
