1994 SKI NAUTIQUE NO START COLD |
QUEBEC
Senior Member Joined: August-30-2009 Location: NEW JERSEY Status: Offline Points: 216 |
Posted: June-16-2011 at 4:10pm |
94 SKI NAUTIQUE HARD START COLD NO FUEL FROM FUEL INJECTORS ON COLD CRANK A TIMES. FUEL PUMP IS RUNNING HAVE PRESSURE, BUT NO TRIGGER FOR INJECTORS. ???? SENSORS PCM DISTRIBUTOR ANYONE HAVE ANY INFO ON THIS. RUNS FINE AFTER STARTS AND RESTARTS FINE ALL DAY
NEVER EVER GIVE UP ON YOUR SELF YOUR FAMILY YOUR FRIENDS AND GOD THERE ALWAYS A NEW DAY
Go into the reference manual section at the bottom there is a GT-40 service manual. I believe section 3 is trouble shooting.
There is a temp sensor (I can't remember which one) but it tells the computer the proper fuel/air mixture. Section 2A17 is the theory of operation which helps understand how the sensors come into play. |
mplummer
Newbie Joined: February-08-2018 Location: Chico, Ca Status: Offline Points: 6 |
I'm having the same issue with my 94 nautique, Cranks but wont start, no fuel from injectors, Once it is running, it runs great all day. Did you ever figure out what the problem was? Water temp sensor???
Thanks Matt |
desertskier
mplummer
Yes, but I don't have the gt40 in my nautique. I have the pcm 5.8 pro boss with a throttle body.
Matt look at your fuel issue thread, I added something there
It may or may not be helpful. |
