  New Posts New Posts RSS Feed - 2005 GT40 5.8 won't run
rob200020 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rob200020 Quote  Post ReplyReply Direct Link To This Post Topic: 2005 GT40 5.8 won't run
    Posted: April-14-2020 at 8:35pm
Engine cranks but cuts off after 2 or 3 seconds. It runs as long as I hold starter.
I bypassed the safety switch. It is good. I sprayed starter fluid into throttle body. Engine still cut off. Put in new plugs.
I never hear the fuel pump before starting. Should I hear it?
I disconnected the oil pressure sensing unit. Didn't make any difference. There is an extra wire on the oil pressure sensing unit. Is it a backup for low oil pressure?
Should I check the pressure on the fuel injection rail?
Thanks
Rob
rob
C_Heath View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote C_Heath Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2020 at 10:00pm
Thanks
Rob
I had the same issue and it was a lose wire on the ignition kill switch. I Put a new Switch on to begin with but as I was installing it I notice that as I was messing with the wires, the fuel pump would run. If I squeezed the wire it would run again to I replaced the connectors and it’s fine. Do you have a key ignition or push button ? Something is causing the pumps not to run. I would revisit the kill switch.
1979 Calipso Runabout (the boat that got it all started)
1988 Mastercraft ProStar 190 (sold)
2000 Pro Air Nautique/GT40
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2020 at 10:06pm
Rob
How did you bypass it and did you check it with the VOM for continuity?
Post Options Post Options   Thanks (0) Thanks(0)   Quote C_Heath Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2020 at 10:14pm
I’m guessing he removed the switch and tied the 2 wires together. That should have cut the fuel pumps on I think.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2020 at 10:30pm
Yes you should hear the pumps prime the rail.
Put a pressure gauge on it then get back with the results.
Post Options Post Options   Thanks (1) Thanks(1)   Quote C_Heath Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2020 at 10:39pm
Run over and look at my fuel pressure tests. Let me know what you think.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: April-15-2020 at 8:39am
2005 and gt40 don't exactly belong in the same sentence .
From your old posts it looks like a 2000 model year boat and it must have a replacement engine that was put in maybe in 2005? There were no model year 2005 gt40 engines, they'd gone the way of the dinosaur by then.
How about some more info and maybe the numbers on the engine ID tag to be sure you're gonna get some good advice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rob200020 Quote  Post ReplyReply Direct Link To This Post Posted: April-15-2020 at 2:46pm
Clarification to engine. I have a PCM 5.8 HO model PLPPOOOM Mfg date 08-05. It is a replacement engine for my 2000PAN. I have push button ignition.
Thanks
rob
Post Options Post Options   Thanks (0) Thanks(0)   Quote rob200020 Quote  Post ReplyReply Direct Link To This Post Posted: April-15-2020 at 3:43pm
Problem solved. A tripped ignition run breaker. Thanks for all your help. It's been a good learning experience for me.
rob
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: April-15-2020 at 3:48pm
Glad it's running.
Since they usually trip for a reason, did you find the reason?
That ID tag is still a mystery.
Could you post a picture of it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote rob200020 Quote  Post ReplyReply Direct Link To This Post Posted: April-15-2020 at 7:37pm
I made a pic. I'll upload as soon as I figure out how to do it.
rob
