  New Posts New Posts RSS Feed - Still Happy with your Protec Conversion?
Nauti Gator View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nauti Gator Quote  Post ReplyReply Direct Link To This Post Topic: Still Happy with your Protec Conversion?
    Posted: June-27-2020 at 7:11pm
Starting to get some ignition stumbles and rougher idle on my carbed 280hp ‘93 SNOB.   I guess 27 years Is pretty good on the old system. Is this currently the best set up to eliminate the Protec? Any insights / opinions?
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: June-27-2020 at 8:58pm
Several members have removed the ProTec system and have installed the DUI high-energy-ignition (HEI) distributor by www.PerformanceDistributors.com. You don't really need all that stuff in the "kit". The link below is a nice write-up by JPASS on his DUI install and ProTec removal.
LINK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nauti Gator Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2020 at 12:33pm
Thanks for that update - sounds like the HEI is definitely the way to go now.. Going to call Performance Distributors tomorrow - I noticed they have 2 different timing curves based upon the rpm of the motor (7,000 and 10,000 RPM) obviously I would want the 7,000. I would like to know how the timing advance curve on that distributor compares to what I have today?. I have The H.O. carbed 285hp 4,400 max RPM motor. According to manual I have a total timing advance of 26 degrees at 3600 RPM. I want to see how the advance curve for the HEI Compares to my current Protec.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2020 at 2:12pm
When swapping to the DUI setup, I wouldn't worry about the number in the manual for the Protec system.
Most everybody that does the DUI swap sets the timing at 10 degrees BTDC and the DUI people will tell you that your distributor will have 24 degrees of advance at 3000 rpm.
That 24 added to the 10 degrees initial will give you 34 total at 3000 rpm and the engine will run good.
I don't remember anybody complaining about the DUI curve or the advance of 24 degrees that it comes with.
If you're worried you could set the initial at 6 or 8 degrees instead of 10 degrees and have 30 or 32 degrees total as a starting point.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2020 at 2:19pm
+1 to what KENO said. The DUI advance curve is very nice. Your engine will like it. My initial idle advance was 8 degrees BTDC originally...but then I changed to 10 degrees BTDC. Engine performance was outstanding. The DUI was every bit as good (if not better) as the ProTec system -- at least in my experience.
And...correct, that you need the 7,000 RPM version. Be sure to get the red model as you will gain several MPH in top speed as red is always faster...
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2020 at 2:30pm
ALWAYS
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nauti Gator Quote  Post ReplyReply Direct Link To This Post Posted: June-29-2020 at 12:15am
You guys are awesome - thanks for your comments!
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: June-29-2020 at 10:29am
I have never actually measured a DUI to have a full 24deg even when that’s what it specifies on the card. Usually closer to 20. In those cases, 12-14 initial on the Fords seems very happy. I definitely wouldn’t be setting it any lower than 10, in any case.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: June-29-2020 at 3:16pm
Let's see, you're checking the advance on a running engine, with belts and pulleys somewhat obstructing your view of the timing marks, while you're trying to keep your head, hands and the timing light from getting chewed up and trying to get a real accurate reading with the engine humming along at 3000 rpm making a bunch of noise.
Meanwhile someone at Performance Distributors is sitting in a chair comfortably checking the advance on a Distributor machine.
Who's gonna get a better reading?
I'd call the in the boat reading a good estimation or check of what they give for the advance
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: June-29-2020 at 3:30pm
I think you may be questioning my ability to use measurement equipment properly but I assure you I am competent... 4deg is not what I would consider margin of error. This is not based on a single reading or single distributor, but many. Haven’t bought or measured a DUI that actually had the full 24- and that’s ok by me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: June-29-2020 at 3:33pm
Whatever
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-29-2020 at 3:34pm
I assure you I am competent....
That's your opinion.
Definition:
"a view or judgment formed about something, not necessarily based on fact or knowledge."
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: June-29-2020 at 3:40pm
Oh brother
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: June-29-2020 at 3:45pm
Shoulda known the opinionated one (Pete) would jump in with something profound.
I've checked timing in the boat plenty of times, but it sure is easier to check a distributor setup on a machine
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: June-29-2020 at 4:12pm
Well sure. I am not doubting their ability to measure, more likely they are not measuring all (or likely many?). The only one that came to me with a spec card was the first one I bought from them 15 years ago. All of the others “typically have 24deg” so I have been told but no spec to prove it was measured and timing checks on the engine have indicated 20-22 on average on the others I’ve bought or checked.
scootdogydog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote scootdogydog Quote  Post ReplyReply Direct Link To This Post Posted: June-29-2020 at 7:37pm
+2. The two DUIs of mine are also around 20° of total advanace, not 24
1999 Python
1980 Ski Tique
1968 Mustang WIP
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nauti Gator Quote  Post ReplyReply Direct Link To This Post Posted: June-29-2020 at 7:49pm
I called Performance today - they said all their 351W 0-7k marine distributors have the same advance curve ending at 24 degrees at 3000 RPM. He suggested to use an initial 10-12 degrees. Sounds like it should be a good set up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-29-2020 at 7:50pm
Ken,
I feel one of your hands on tests would be in order.
Orlando76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: June-29-2020 at 8:10pm
🍿, Get your popcorn, I got it hot and fresh....
1976 Ski Nautique 351 Escort
1TAZZ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1TAZZ Quote  Post ReplyReply Direct Link To This Post Posted: June-29-2020 at 8:52pm
Funny thing I seen this post today, I did the DUI swap om my 92 EXCEL last year and have lost two ignition modules. Lost both of within 20 hours run time . Backed my boat off trailer Sat and it died right on the ramp no spark. So I call them today and their TEC guy t told me that with our boats we must run a Neg wire from our battery to the distributor housing. I have read all the links posted and have not seen anyone doing this . I will do this to my boat this weekend I hope it works getting tired of buying these DUI modules. I will never take my boat out without a extra module again.
Lake Wylie NC
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: June-29-2020 at 9:13pm
Years ago my dad got stuck multiple times in his Prestolite point equipped boat. Condensers were always burning up. Being a center console inboard it was tough to work on the engine, Finally in disgust he pulled the distributor. Due to saltwater use the distributor had corroded where it contacted the block. He cleaned that and added a ground wire. I have since added grounds to my two as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: June-29-2020 at 9:24pm
much insightful.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1TAZZ Quote  Post ReplyReply Direct Link To This Post Posted: June-29-2020 at 9:31pm
Thanks Gary I feel better about this advice now. My wife has got to the point where she wont even go out in this boat. The old PRO-TEC let us down a few times and now this .
Lake Wylie NC
RealDeez View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RealDeez Quote  Post ReplyReply Direct Link To This Post Posted: June-29-2020 at 9:33pm
My 93 has had the protec replaced since before I got it.
I have the mechanical distributor... not even sure what brand. It has given me no problems. Runs a little rough before it's warm but takes like 3 minutes to warm up then runs perfectly.
1400+ hours on the motor so I'm guessing the pro tec was replaced years ago.
I may go DUI at some point if the coil/ points give me trouble but right now it doesn't worry me a bit.
Lake James, IN
93 Sport Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1TAZZ Quote  Post ReplyReply Direct Link To This Post Posted: June-29-2020 at 9:49pm
My 1990 had points and it never broke down me . If yours is not giving you any trouble I would just tune it up and call it good .
Lake Wylie NC
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: June-29-2020 at 10:13pm
If you're dead set on running a ground wire to the battery, you should probably read the thread in the link and the link that's in that thread about "ground loops".
I'd ground it to the block and not directly to the battery, but then again if your ground from the body to the block by way of the holddown bolt is clean you don't need a wire.
You'd think all these manufacturers would have put a ground wire from the distributor to the block if it was really necessary.
If you ground to the battery and have an issue with your big main ground wire then every bit of current wants to go through your new distributor ground back to the battery. So as an example, you turn the key to start the boat and all that starter current wants to go to the battery through the distributor housing and your new kinda tiny little ground wire.
I think I smell smoke
Grounds are funny things.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: June-29-2020 at 10:16pm
Ken,
I don't think that's necessary, besides I misread your quote above and thought you said I should have one of my hands on my testes..............so I've been preoccupied for a while
Besides, I'd have to steal one from a friends boat right now to test it "my way".
Me and my "backyard distributor spinner" machine agree with the quote below
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: June-29-2020 at 10:19pm
Since you don't know what ya' got, maybe a picture would be good and another picture with the cap off too
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nauti Gator Quote  Post ReplyReply Direct Link To This Post Posted: June-29-2020 at 11:39pm
5
Tazz you're not making me feel too good right now since I already have the distributor on the way.   I've cleaned all the grounds to the block and battery and I can't imagine why the distributor hold down wouldn't work?
Keno - very good point
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: June-30-2020 at 12:26am
We had a saying- ground is ground the world around.... I ran my distributor ground to the block.,it cost nothing
