Anti Freeze |
Otto Throttle
Senior Member Joined: October-02-2017 Location: Cleveland OH Status: Offline Points: 385 |
Posted: September-24-2023 at 6:08pm |
What type of antifreeze do you people use when winterizing your engine? Are used to use the -75 from Menards, but today I read on the label not recommended for engine use. I want to try to find some thing that is not going to create problems for animals. In other words, I don’t want to have them, licking the Eyth glycol and dying.
Any suggestions would be great! |
Otto
So.........you've had no problems related to using this stuff for how many years now?
Suggestion...............keep using it and don't worry Signed "Funny Guy"
“Not recommended for engine use” = as a coolant. It’s fine for winterization.
Otto Throttle
Thank you… getting lost in the mire of splitting hairs! You should see me in long range shooting! Thanks! Makes perfect sense!!!!
Otto
Will this be the shortest "Otto thread" ever
Otto Throttle
There is that funny guy again!!!!!
Otto
DayTony
Gold Member Joined: June-30-2013 Location: Salem MA Status: Offline Points: 832 |
Most people when winterizing never run their engine long enough for the Tstat to open and fill the block anyways so i always recommend pulling the drain plugs and draining the block, as well as the manifolds, then all you have to worry about is the mufflers and RW pump. for that just pull the hoses off the back of the RW pump and for the mufflers i just lift the tongue up in the air or park on a hill and drain it before parking for the winter.
I have never used antifreeze in my bfn and winterizing only requires 3 tools 1/4 square drive socket(for block drains) 7mm socket driver (for hose clamps) 9/16 allen and combo wrench (for the manifold plugs) And some fogging oil or atf whatevers around.
1988 Barefoot nautique-454
