  New Posts New Posts RSS Feed - 1956 Collegian restoration
 Post Reply Post Reply Page    <1 5678>
RainDog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RainDog Quote  Post ReplyReply Direct Link To This Post Posted: March-17-2024 at 11:27am
That there is a might slight swim platform, AA...
Mojo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mojo Quote  Post ReplyReply Direct Link To This Post Posted: March-18-2024 at 8:36am
Looking good Alan, as always.. Keep those steps up Thumbs Up haha
Moj'
05' SV211 TE
73' Martinique
had:96' SNOB
had:76' Nautique
had 77 Tique
81nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: April-10-2024 at 9:51pm
So I have all the deck plywood installed and started laying out the pattern for the planking.  I ended up making a 20’ straight edge by laminating some 1/4” plywood strips together.  Used that to lay out the planking plan and will use it as a router guide for cutting the deck seams.
Also steam bent the piece that goes across the deck at the transom,  I think that’s the last time we’ll need the steamer on this on.
I ended up rebuilding the dash as the old one had been altered from the original gauge layout quite severely and repairing all the holes was going to be more work than fitting a piece new piece.
Here’s the fore deck layout,  the deck had been replaced by the previous owner and what they put back was not even close to the correct pattern.  From what few photos I could find 1956 had a one year only deck pattern and had a nice alternating staining between blonde and the red mahogany.  That will become more apparent as I gel the decking installed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morfoot Quote  Post ReplyReply Direct Link To This Post Posted: April-11-2024 at 5:40am
Retirement looks to be really rough and hard on you Alan. Keeping busy is the secret to a long and healthy one. Fabulous work as always. She's gonna be a Purty Boat. Any thoughts on a name for her?
pjsmoreno View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pjsmoreno Quote  Post ReplyReply Direct Link To This Post Posted: April-11-2024 at 9:37am
Love watching your project coming along. Patience Patience Patience Come with age I think.... At least that is how it is with me.
Kristof View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kristof Quote  Post ReplyReply Direct Link To This Post Posted: April-16-2024 at 8:35am
Oh she gonna look purty allright!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: April-17-2024 at 11:45am
 Started building the engine bay hatch.  I altered the framework just a bit to try to get me some more height for clearance to the flame arrestor.  The old y block that came out had side draft carbs but the 302 going in has a typical 4 barrel and needs more height than the old hatch design could offer, my measurements show it’s still going to be real close.  If the hatch doesn’t close we’ll figure it out when we get there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: April-17-2024 at 5:44pm
Few more shots of today’s progress.
Figured it was time to quit for the day when I tried to install the last piece of plywood upside down onto fresh 5200 and made a mess.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: April-22-2024 at 1:21pm
Hatch planking just needs a little more fine tuning and it’s ready to be fastened down.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCH20SKIER Quote  Post ReplyReply Direct Link To This Post Posted: April-22-2024 at 3:57pm
Sawdust and shavings  Smile
Nice work as always
Post Options Post Options   Thanks (0) Thanks(0)   Quote pjsmoreno Quote  Post ReplyReply Direct Link To This Post Posted: April-23-2024 at 3:52pm
I can smell the fresh cut boards! Looking better every day!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kristof Quote  Post ReplyReply Direct Link To This Post Posted: April-24-2024 at 2:27am
Nice solution for the engine height! Looks like if it were engineered from the factory. Great work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2024 at 10:10pm
Thanks for the compliments.
Fitted the bow deck inserts and shaped the hatch cover.  Next up will be the cover boards that run the length of the boat, been avoiding them because I think they’re going to be a challenge.
Very happy with the hatch, I decided to try something and it worked out very well.  Once I built the hatch frame I shimmed it in place to set the gaps then installed and shaped the decking in long pieces that run all the way to the transom.  Now that its complete I’ll cut it free from the rear deck and end up with a perfect deck seams and gap.  I didn’t do this on the Hurricane and I spent a ton of time  and effort trying to get that hatch to look good and was never really happy with it, this process worked out great.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Donald80SN Quote  Post ReplyReply Direct Link To This Post Posted: April-28-2024 at 10:55am
True Craftmanship.
1968 Ski Nautique, Project.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: May-04-2024 at 9:31pm
Got the outer cover boards fitted.
I’ll get these permanently installed and finish shaping them then get to work on the rest of the infill decking
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2024 at 9:08pm
Well it’s rained 3 days this week so lots of progress.
All that’s left on the deck is the infill on the bow.  Got everything glued down today.  Cut the engine hatch free also, very pleased with the way that worked out.  Everything lines up very nice.  I was able to find some very nice wide mahogany so the rear deck pieces are actually done in a single piece.  Resawn and book matched on each side of the hump.  That area will be blond and should look nice.
I’ve made a few mistakes along the way but always find a way to recover.  😊
Post Options Post Options   Thanks (0) Thanks(0)   Quote fanofccfan Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2024 at 8:14am
I am always in awe of the skills you have.  Amazing work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote pjsmoreno Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2024 at 3:38pm
Only you will see your mistakes! Looking great!
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCH20SKIER Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2024 at 8:44pm
That will be another masterpiece you have brought back to glory
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: May-15-2024 at 11:25am
Other than building the rubrail the woodworking phase is done.  Taking a week off to visit the grandkids then back at it for final sanding.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: May-25-2024 at 11:16am
After two days of finish sanding it is ready for bleach.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: May-25-2024 at 11:30am
The precision with every detail is so impressive!
I'm noticing something not boat-related.  I went back to look at some of the early posts on this boat, your discovery of expected issues and unexpected ones like the bottom being oil saturated.  As I read and looked at pictures, I noticed the same bike with the same black drawstring bag hung high on the starboard wall.  You need to take a break and go for a bike ride! Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Donald80SN Quote  Post ReplyReply Direct Link To This Post Posted: May-26-2024 at 11:13am
She is beautiful.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: May-26-2024 at 8:31pm
LOL,  the only thing that gets less use than that bike is my treadmill.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: May-30-2024 at 6:13pm
Called in some help today from the Sunday Drive crew.  Renee and Evan came up to help Dana and I get the boat stained.  Got a few small touch ups to do as I missed a few scratches that the dark stain exposes but it came out pretty good.   The blonde color is a little yellowish but will turn to more of a gold as we get varnish on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: May-30-2024 at 9:53pm
Oh c'mon now.  That just is too gorgeous with the contrasting colors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fanofccfan Quote  Post ReplyReply Direct Link To This Post Posted: May-31-2024 at 9:02am
That looks amazing.  Thanks for sharing the progress via pictures.
2001SAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2001SAN Quote  Post ReplyReply Direct Link To This Post Posted: June-01-2024 at 5:37am
Wow!
A little knowledge is a dangerous thing...
2001 Super Air Nautique
1989 Fairline Corniche 31
www.bannrivercruises.co.uk
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67 ski nat Quote  Post ReplyReply Direct Link To This Post Posted: June-02-2024 at 8:54am
Gorgeous and fast
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75 Tique Quote  Post ReplyReply Direct Link To This Post Posted: June-02-2024 at 11:28am
Going to be another stunner
