  New Posts New Posts RSS Feed - ’79 Carb in an ’83?
’79 Carb in an ’83?
freemanca View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote freemanca Quote  Post ReplyReply Direct Link To This Post Topic: ’79 Carb in an ’83?
    Posted: August-14-2007 at 8:03pm
There is a used Holly carb that came out of a '79 SN on eBay. Would you be able to run this in an '83 SN? Seller doesn't know if it's 600 or 650cfm though.
I have to replace mine and ran across this on eBay.
Carb
Thanks,
Chris
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: August-14-2007 at 11:30pm
that's not a marine carb, It wasn't a stock carb for a PCM motor or even anything that would have been in a SN
Post Options Post Options   Thanks (0) Thanks(0)   Quote freemanca Quote  Post ReplyReply Direct Link To This Post Posted: August-14-2007 at 11:55pm
Wow, really? Well that's the problem i have now, PO put auto carb on.
Thanks,
Chris
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: August-15-2007 at 12:39am
Yes, its nonmarine, and spreadbores don't go on fords. Silly vacuum dashpot on it too.
The seller is smokin something
River Rat to Mole
nuttyskier2002 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nuttyskier2002 Quote  Post ReplyReply Direct Link To This Post Posted: August-15-2007 at 3:10pm
This E-bay seller is either a lier or he doesn't know what he has. His ad states that this is a vacuum secondary. It's very plain to see by the pics that this carb has mechanical secondaries. Also it is a double pumper which means it won't be easy on gas. There's no electric choke and as stated above it is a spreadbore which will require an adapter for your manifold. And yes, it's NOT a marine carb. Stay clear!
Former boats:
88 Ski Centurion Tru Trac II
59 Chris Craft Capri (woody)
Post Options Post Options   Thanks (0) Thanks(0)   Quote freemanca Quote  Post ReplyReply Direct Link To This Post Posted: August-15-2007 at 4:12pm
I think he has linked to pics from the web of a carb and is not showing the actual carb off the boat. I asked for actual pics, but no response.
Chris
