100 Amp alternator upgrade |
Post Reply | Page <12 |
Author | ||
63 Skier
Grand Poobah Joined: October-06-2006 Location: Concord, NH Status: Offline Points: 4269 |
Add between the 2 thinner bushings a flat washer or fender washer, might just shim it out enough to not rub. Just guessing, altering the bracket is likely the better solution, but this would be easy to try. i always have spare belts with me. And though others here may cringe, a slight misalignment on an alternator belt is unlikely to snap the belt.
MrMcD
Grand Poobah Joined: January-28-2014 Location: Folsom, CA Status: Offline Points: 3734 |
Well we have to learn something every day! Now if I can remember the lesson.🥸
I just had my "finals". I'm done learning- I'm taking the rest of the summer off. But for extra credit could you use the large diameter spacer and trim down one of the smaller diameter ones by 3/16" ?
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11050 |
Since you're still looking for a bracket and I don't know if you got one from TRBenj in his parts thread, I thought I'd post an alternate way to line things up.
The quote below is from the parts thread, updating the situation.
You may think "is this guy off his rocker or something" , he wants me to hack up my alternator, but here goes.......... Instead of performing surgery on the bracket, do the surgery on the lower mounting ear, boss or whatever you want to call it on the alternator. For example, say you cut off 1/4 inch from the back of the boss, you'll be able to slide the alternator back 1/4 inch and use washers, to take up the gap in the front or use washers front and rear as necessary to get the alternator right where you want it. I did this fairly recently with a different brand alternator from a different outfit to get it lined up right. You'd have a choice of tools to shorten the alternator boss, like a 4 1/2 inch angle grinder, a hacksaw, a belt sander etc. All things that a typical backyard hack might have hanging around Me, I like my angle grinder for "precision machining" like this It's easier than modifying the bracket and if you take extra off, you use washers front and rear to get it just right as mentioned above.
MurphyCO
Senior Member Joined: December-15-2015 Location: Murphy NC Status: Offline Points: 126 |
Tomrupp
Groupie Joined: October-14-2021 Location: MI Status: Offline Points: 80 |
My pulley is crooked too. Angle grinder is one of my favorite tools. Thanks for the suggestion.
Tom
94 Ski Nautique Open Bow 351 with Carb 95 Double Decker Aqua Patio with 50hp Honda (3 carbs). |
There I was, playing with an alternator yesterday and I thought of this thread
So was the surgery successful or did you kill the patient or maybe postpone the job?
MurphyCO
Postponed surgery for now; grandkids wouldn't let me turn the engine off long enough during the holiday. I'll get back on it soon and report in. Thanks! Gary
gun-driver
Wow you couldn’t turn it off since July 2021 your gas bill must be huge.🤣
