More like a Briar Patch |
Post Reply | Page <12345 6> |
akabulla
Gold Member Joined: November-15-2008 Location: United States Status: Offline Points: 649 |
Thats pretty cool! How are you going to lay the carpet so you don't see the edge from the floor to the side? I looks like there is a lip.
Keep the pictures coming! |
Bj,
I admire your ambition with the stringers and certainly the floor pan (even though it's not original!!). Did you ever consider and talk to your glass guy about using one of the diamond non slip patterns on the floor pan like the 60's Mustangs? Considering what I've seen in the pictures, I'm sure he knows about the stuff you get for the pattern. Just curious!! |
BuffaloBFN
Doin' the South proud!
hasbeenskier
The edges will be glassed smooth and the surface will be gel coated with a pumice added to provide a non skid surface. No Carpet.
hasbeenskier
hasbeenskier
Pete,
I missed your post about the diamond pattern. Yes I am very familiar with it and the boat yard even has a form of it. I personally prefer the pumice non-skid surface. I have a spearfishing buddy with the diamond non skid on his Pursuit and those little diamonds are sharp. (LIke when kneeling on it) The diamond pattern does scrub clean easier though. |
hasbeenskier
hasbeenskier
Subsequent to glassing down the deck, holes were cut in to the deck for the insertion of foam. Upon it expanding out the holes and thereby filling the compartment cavity the pucks were replaced and glassed back.
hasbeenskier
hasbeenskier
hasbeenskier
akabulla
Sorry if I seem dense but I am really intrigued by the floor and don't fully understand the construction. If I understand correctly you used something like plexiglass or lexan for the base. Then applied your laying process on top of that and the plexiglass stays as part of the floor or you removed it before glassing it in place?
hasbeenskier
The Work table is tempered window glass. The molds are built on the top of the glass. Upon completion the deck section is popped up from the table top and flipped over giving a very smooth gel coat surface.
hasbeenskier
akabulla
Gotcha, that makes sense! From the picture when you put it in the boat it looks like you can see an edge that looks like glass. What am I seeing there?
hasbeenskier
It is foam core that was glassed along the edges for a cleaner finished
look. Nida core is honey combed and not a very clean finish. I will have the pictures I promised in a few more days. |
hasbeenskier
hasbeenskier
Finally, the engine cradle is done. I went back to the post when I anticipated the cradle to be completed.... 12/09. I am glad I'm not under contract.
hasbeenskier
hasbeenskier
hasbeenskier
hasbeenskier
hasbeenskier
hasbeenskier
hasbeenskier
hasbeenskier
While I have your attention. Gary's 79 BFN was shot with gel yesterday.Now it is going to sit several days then... sand and buff.
bj |
hasbeenskier
hasbeenskier
hasbeenskier
hasbeenskier
hasbeenskier
akabulla
Glad to see you back at it! Looking good!
DrCC
BJ, It is refreshing to see someone else still believes in original resin.
Note: On BJ's pics of lay-up, clear! No white, no air bubbles. AT |
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21135 |
BJ, looks great- as usual! Gary's '79 looks mint as well. Youre still a few steps ahead of us... our cradle needs some grinding and rewelding.
hasbeenskier
Hey Tim, Thanks, It is a very slow process. It seems like everything else is a priority. Your project is helping me along. You and your dad have taken some large steps.
bj |
hasbeenskier
hasbeenskier
I spent the day working on the BFN mounted both fins, the drain plug,and the raw water through hull pick up. Gary built a stainless strap with two gussets at the top and mounted the transom lifting ring. Nothing ever moves fast, but it is moving.
hasbeenskier
hasbeenskier
hasbeenskier
hasbeenskier
hasbeenskier
hasbeenskier
hasbeenskier
hasbeenskier
For the sake of conversation the first of the three photos in this post show four green pieces of 2X4 channel on the stern's deck. They are fiberglass. I am going to glass them down, then mount the fuel tank down. There will be rubber between the mounts and the tank.
bj |
hasbeenskier
BJ,
That bracket will lift the Queen Mary!! Nice work. Now I sure Tim's doing some thinking on a new project! |
hasbeenskier
Thanks Pete, Coming from you it is like getting a blue ribbon!
bj |
hasbeenskier
Donald80SN
Grand Poobah Joined: January-12-2009 Location: Denver, NC Status: Offline Points: 3893 |
BJ,
Very nice. This boat will outlive all of us. Donald |
