PN# for shaft and coupler??? |
ripster92
Senior Member Joined: April-13-2007 Location: United States Status: Offline Points: 254 |
Posted: June-06-2008 at 11:23pm |
This sounds like a dumb question, but do any of you, by chance, happen to know the Correct Craft part number for a shaft and coupler for a 92 SNCB w/ 351HO and 1.23 trans? I know the dimensions but, I called General Prop to order one, and they said that I needed the PN#. I sure would hate to call up a dealer and ask this when I'm not buying it from them
Thanks. |
1992 SN Black w/ Yellow
behindpropeller
I would get the ARE from skidim. Much nicer system and the cost is less. I am impressed with the ARE workmanship.
Tim |
ripster92
Wow Tim! I would have figured that GP would have been much less. I'll trust ya on that one. Thanks for your help!!! I'm putting the order in tonight.
ripster92
It's ordered... Thanks again.
eric lavine
your right Tim, anymore the single tapers are right up there on price with the doubles,
I have a call into another place that specializes in the aquamet shafts. I gotta price on a 60" piece of ground and it was 120.00 to get a break you have to buy a 20' ft length, then the machining, then the coupling to match..... anymore the minimum you are going to find the single taper for is $280.00 and what the hell you may as well go for the double taper for the couple dollars more |
ripster92
Skidim - 299.00 with the discount and shipping for the ARE double taper.
eric lavine
280.00 for the single at General, go with the double
anthonylizardi
Gold Member Joined: July-25-2007 Location: DFW, TX, USA Status: Offline Points: 836 |
I went thru the same thing ordering a shaft from General. Apparently you got the new guy at General. I post the same question and everybody told me to call again. I called again and that's when I found the price $350 after facing and coupler, no S/H. No brainer, I went with the double tappered from Ski Dim.
ripster92
I should have mine in a couple days. It still amazes me that they would ask to retrieve a PN in the first place. You'd think that they would lose a lot of orders this way.
