  New Posts New Posts RSS Feed - stainless steel hull strip repair
Tellarico View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tellarico Quote  Post ReplyReply Direct Link To This Post Topic: stainless steel hull strip repair
    Posted: July-06-2008 at 5:16pm
Can the stainless steel strip that goes all the way around the hull at the deck be polished or should I just look for a new one? Mine is not dented but very scratched.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: July-06-2008 at 10:19pm
Depends how much you want to spend. It's about $65.00 for 12 feet at boaters world or west marine. Here's the place who makes it and the diffrent profiles.
http://www.tacomarine.com/cat--Aluminum-Rub-Rail--cat2_aluminum_rr.html
Mine is aluminum, not sure what else they used,but they do have stainless.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tellarico Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2008 at 12:21pm
You are probably right mine is aluminum also. I may spend the bucks if the rest of the boat comes out as good as I hope. Thanks, Paul
