water in fuel |
k.o.
Senior Member Joined: January-11-2008 Location: Aruba Status: Offline Points: 363 |
Posted: August-31-2008 at 12:52am |
well today my boat started acting up again with it's fuel system carb flooding again so i think time for a rebuilt. the thing that bother me is that the last rebuilt was 4/5 months ago the boat get used once or twice a week. Do you guys think it's time for rebuilt or just clean it?
does anybody uses fuel stabalizer? does it helps with water in tank? i already have a watrer/separator change every 3 month and empty after 4 uses. my dad sugested putting another water separator. will 2 separator help or will i have same results? i know it's water in fuel since I opened the bowl to clean it and there was water in it and it has lots of smal debree in it i think a fuel filter is also in order? any other sugestions?? thanks in advance for any help. |
nuttyskier2002
Gold Member Joined: September-28-2005 Location: United States Status: Offline Points: 669 |
Sounds like you need to find out what's causing so much water in your fuel tank. Where are you buying your gas? You shouldn't need to install two water separating fuel filters. Where does your boat get stored? Is it very humid there? When not in use, is your fuel tank near empty?
Former boats: 88 Ski Centurion Tru Trac II 59 Chris Craft Capri (woody) |
74SkiNautique
Senior Member Joined: July-29-2008 Location: Lynchburg, VA Status: Offline Points: 228 |
The only time I use a fuel stabilizer is in the Winter. In the summer, we use it so much there is no need. You should never have water in the fuel unless your cap is left off!
74SkiNautique
74SkiNautique
Also, when I store my boat, I ALWAYS fill the tank full! This way, no condensation will form in the tank!
74SkiNautique
k.o.
yes it's almost empty we think it happens via condanation the boat is parked sometime infront of my house or in my grandmothers yard. The yard has a few three to cover the boat a bit and i have a boat cover.
it hot hear 29 to 30 degree every day and 26 to 28 degree celcuis every night. with the prices here i have to gettin more tips at work for full tank. about 300fl that's 171$ we fuel at valero |
k.o.
well an update. after i clean up both bowl of the carb it kind of stop leaking what filter should i put one i really want a fuel filter since i get allot of small debree trough the carb. we ran it today ran pretty good.
now i have baterie issue. |
bill1
Senior Member Joined: May-27-2007 Location: United States Status: Offline Points: 151 |
i, too, am curious how the water is getting there into the tank. grandma doesn't have any water sprinklers running around the back of the boat getting into the tank via the vent, does she?
bill
k.o.
no sprinklers.. i once had a theory but i don't think it's a good one maybe one of you can tell me if i.m wrong or not. we have fiberglass platform and it pushes lots of water when reversing and most of the water end up splashing on the transom compared to a teak platform?. so i tought once maybe the water that we push while reversing finds a way true the vent??? my brother and father say it ain't posible since the vent's opening is pointing down. so you guys tell me if i'm wrong or correct.
SNobsessed
The water could be coming in the gas you are buying. They could have condensation problems too, or just be crooks.
We have had 3 separate gas station busts this last year - one guy was heating the fuel lines so it would expand & fool the pump meter! |
