  New Posts New Posts RSS Feed - 78 CC - How is the pylon attached?
Bill336 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill336 Quote  Post ReplyReply Direct Link To This Post Topic: 78 CC - How is the pylon attached?
    Posted: February-07-2005 at 1:46pm
I'm in the process of taking apart my 78 American Skier. The engine is still in so my access to the bottom of the pylon isn't very good. It looks like the bottom goes over something that's glassed into the hull, then it has an aluminum plate that's bolted to the floor. The pylon is currently rock solid, but I'm wondering how the bottom is attached to the hull?
Thanks in advance for any help...
David F View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2005 at 2:45pm
The pylon is bolted to the floor between the engine bay and battery box. Simply remove the four machine bolts...they have a plate, washer and nut on the bottom side. Then lift the pylon straight up and out. The bottom of the pylon has a peg/pin that sits in a cup socket glassed into the bottom of the hull. Unfortunately, the pin and socket are ferrous metal pieces that tend to rust. Enough rust and the fit is sloppy leading to excessive movement of the pylon. Also, look for rotting of the floor where the pylon is bolted.
jameski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jameski Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2005 at 6:43pm
David,
My pylon has a little bit of play - probably rust on the bottom peg/socket you referenced. Is there any way to adjust the play out?
current boat
94 Sport Nautique
previous boat
78 Martinique
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2005 at 8:04pm
Sure. Remove the pylon. Clean the peg/pin to remove ALL rust. Epoxy coat the peg/pin or as a minimum spray it with cold galvanizing compound. Once the treatment dries, apply a liberal coat of wax evenly.
Clean all rust out of the socket in the hull. Do not paint or wax the socket. Protect the hull around the socket with wax paper and seal the paper to the outside of the socket well. Pour epoxy into the socket...just enough so that the pylon peg will not displace so much that it runs all over the bilge. Now, replace the pylon and bolt it down properly. When the epoxy dries in the socket, the wax on the peg will prevent the epoxy from sticking to the peg, but the socket will now be the proper size for the smaller peg.
Just a word of caution: If the peg has large pits in teh surface or is irregular in shape, then you should make sure it is smooth before doing the above procedure or you will not be able to easily remove the pylon agian.
77stang View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 77stang Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2005 at 9:41pm
David F,
A note about
".....Now, replace the pylon and bolt it down properly. When the epoxy dries in the socket, the wax on the peg will prevent the epoxy from sticking to the peg, but the socket will now be the proper size for the smaller peg."
BRILLIANT!!
