  New Posts New Posts RSS Feed - TCW-3 outboard oil
TCW-3 outboard oil
74SkiNautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 74SkiNautique Quote  Post ReplyReply Direct Link To This Post Topic: TCW-3 outboard oil
    Posted: November-01-2008 at 10:44pm
All 2 stroke outboards require TCW-3 2 cycle oil. On the jug it says for use in air cooled engines also. It shows pictures of lawn mowers and a chainsaw. All of our yard equipment is 2 stroke. The TCW-3 oil works out to be $0.08 per oz, and the 2 stroke oil is about .60 per oz. Can I use the TCW-3 oil to mix and use in our engines?
74SkiNautique
boat dr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boat dr Quote  Post ReplyReply Direct Link To This Post Posted: November-01-2008 at 10:58pm
74 TCW 3 =
Two Cycle Water Cooled Type 3
Don't think the premium oils have a picture on them, Merc Quicksilver or Yamaha Yamalube. These are the only oils I use or recommend to my clients,.08 should only be used for bar oil in my Husky chain saw.
Quality equipment should only be fed quality oil. If you own a cheap weed eater or brand X yard tools by all means use cheapo oil, they will not live long enough to care.
Oil and blood are two places I would not comparison shop befor the purchase.............Boat dr
Post Options Post Options   Thanks (0) Thanks(0)   Quote 74SkiNautique Quote  Post ReplyReply Direct Link To This Post Posted: November-02-2008 at 12:33pm
The merc quicksilver has the pictures on the jugs. Will the oil provide the lubricity for these high temp aircooled small engines. Our machines are high quality and want the best for them. The outboard oil was a thought because it is only 8 cents per ounce.
74SkiNautique
eric lavine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: November-02-2008 at 12:47pm
all is true, if you drink cheap beer you feel like *************** the next day...sorry BD, you remember that though
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-03-2008 at 11:11am
Chris,
If all your yard equipment is high quality then run a high quality oil. If it's "Walmart" equipment then run the cheap oil as it's "throw away" at the end of it's usefull life anyway!
