Paint color for Interceptor Engine |
Posted: January-18-2015 at 9:15am |
Roger,
I have the later 60's 312 so I feel the sea foam green I've been looking at is appropriate. I agree that the 50's engines were painted slightly lighter. I've been looking since I've never felt the alpine green some have used is correct. The next time I'm over at my Sherwin Williams store, I'm going to take a close look at their color chips since they can custom mix an alkyd. |
uk1979
Pete, from what I have found there are 2 shades used,darker on Interceptor flat side logs early 60's on....more light blue on 50's round log engines. I have a set of round logs still with factory paint I will use to match.
Lets have a go
[QUOTE=reidp] This is the same color Phats is referring to above in a more true sense. But I believe it's still more blue than the original Interceptor green is supposed to be. This Chrysler "green" as they call it reminds me to a much lesser degree of the crazy Dupont Mystic paint, as it looks different in so many different lights as Phats noted.
The first generation Interceptor engine color has been on my mind for years. I came across a case of touch up made for refrigeration compressors and it's damn close. It's marked as a "seafoam green" and not the "alpine green" that many have thought was close. I sprayed some so now I'm ready to start my 312 rebuild when needed. Even though internet color really isn't a good example, I did search out seafoam and it sure is closer than the alpine. |
GM needs 25 billion to re-tool, i would imagine the concept is the same, too much $$$$$ to re-tool
Bruce, The down angles bolted on to the tail ends just like a reduction drive does. Yes, pretty simple. When the Dearbo trans had reached it's limit on HP's they had done everything possible to save the design like go to a self contained hyd. pump. However, the other components just couldn't handle it. I feel it was at that point that they realized that it was easier and cheaper to just buy the Velvets than to design/retool to a completely new trans. B/W had gotten the majority of the market by then anyway! It would have been a up hill battle!! Eric, I think the early V drives I'm thinking of are Chryslers. Not too many around. I've only seen a couple - In Shepards |
That down angle seems to be just an adaptor to the standard trans. Pretty simple.
I wonder why Eaton didn't improve their Dearbo rather then outsourcing to BW as their engines got more powerful? |
the v's used u joints, bad idea as you know....Don cant figure that out... the new PCM v is the ticket, 2 gears no maintanance, its called the skivee, correct me if the spelling is wrong...to this day no one can cut a gear like our fellow Europeons,
I would imagine Walter's is searching for new business, I talked to a guy last week from somewhere (cant remember ***************) He had a run in with Don, the conversation was quite amusing. |
no down angles out the back from Paragon, we tried in the 80's, couldnt get it to go, kept burning bearings and dollars
Eric, This would be the mid to late 50's and I do believe it was. Eaton also made the Dearbo is a V drive. Same down angle box but the output was under the trans. I don't feel the Dearbo V was the first though. I've seen some very early 50's V's. Paragon??? (mechanicals) |
possible the first down angle? evolution
Bruce,
It's is surprising what a couple cans of paint can do!! The picture you found on the internet has got to be Steve's Century. It's a single plank hull and I recognize the floor covering. It's also the first generation Y block exhaust manifolds like he has. I had this picture here on my office computer before he dropped it in the boat. |
Pete, that pic of the Interceptor I found on the internet does look like it's in a Century. It was on a site I googled about Dearbo trannies. It was a forum. Don't know who posted it.
I like that you can just spray the hoses, wires and everything else and be restore correct. Makes it much easier for the novice. And what a difference $20 in spray paint makes. |
Doug, The difference in the "preferred" method of restoration between automotive and marine I feel goes back to the common practice of auto customization. Dressing up a engine was so common that it is probably the accepted "restoration" on cars after WWII. I do know that the older auto restorations are judged in the same manor as boats. In other words, you don't go putting chrome head bolts on a 1933 Auburn Boat Tail Speedster. What organization was the judging under that dinged you? Does this organization have judging guidelines? |
75 Tique
Definitely. Remember the 37 different varieties of Yucatan (yuckytan) Yellow we were looking at a few days ago. But whatever color, there have been a bunch of good looking engines in this thread. |
64X55
Senior Member Joined: January-19-2007 Location: United States Status: Offline Points: 214 |
Phatsat67 -- GTX's were sweet! I saw one on the road a few weeks ago. Neat cars!
Inboards Rule!
phatsat67
Thanks reid. Thats a much more true picture of what the color should look like. Craig, that is in a 67 GTX that I just scrubbed up online but It has the incorrect air cleaner on it. The plymouth motors said super commando and the dodge motors said magnum. It should have had dual snorkles on it.
But this isnt a mopar thred haha sorry. |
64X55
Waterloo -- Thanks, of course I'm getting a little scared at this point. When I first saw it, it looked like this...
. ...and I had that vision of what it could be and the thought that it wasn't too bad, and it could look like this: Guess we'll see, one way or another how it ends up. Lot's to do! M3Fan -- You're right, but it sure is fun lookin' at all the purdy pictures! Also, to compare the color within the same picture is accurate. Those last pics I posted of my engine (above) are enough for me. I'm going with the Alpine Green. What do you think 2 more cans? Or 3 more? Already got one can. Will need to do the tranny too. |
Inboards Rule!
I agree. Look for a spot on the engine that looks to be original and then like I said, come as close as possible. Interestingly I got a email for JD (nautique51). He's the one with the dial up problems and can barely get on CCfan. He saw this thread and here's some of his comment: "When the original color wasn't available we had to color match to a hidden area that might not have been altered because of heat." He's done a decent amount of antique and classic engines. |
M3Fan
Gang, comparing colors on computer monitors of digital pictures is a total crapshoot. Of about a million factors in how the colors are going to look, a few would be:
- White balance of the camera - Saturation levels of the camera - Ambient Lighting/Flash of camera - Color calibration of monitor - Ambient light in the room that has the monitor And so on and so fourth. The only way you're going to see if that paint cap matches paint on an engine is if you physically set the can next to the real engine in the same light! |
h20loo
Senior Member Joined: August-30-2008 Location: Canada Status: Offline Points: 225 |
Pete- that takes me back to a few years ago at a car show. I was showing a 67 dodge and the bypass hose was painted along with the spring clamps. I was faulted heavily for this. What I found amusing is that this was the original bypass hose and had never been changed or altered and I had showroom floor photos to support it. 64x55- I'm one of those guys that looks at something and see it as it could be. Love your photos! However this ability often gets me into projects that should never have been started by me!!! |
70 Mustang project
Alan,
The detailed 312 would get hit with a point deduction by the majority of ACBS judges. A good example of detailed judging was a point deduction on a pre WWII upholstery job. The owner of the boat filed a complaint but didn't win. He used staples instead of tacks to attach his new upholstery. |
Reid, It's only more of a challenge as "newer" boats with the different engines are being restored. Eveyone knows what paint to use on the old Chryslers, Chris's, Grays, Kermaths, etc. The key with the "odd" engines is to get the color as close as possible and then it's not a issue. Interestingly, the hotter topic is the over restoration of engines. Polished and lacquered brass or acorn head bolt nuts come to mind (chromed is even worse)! The trend to originality is going back to the way the engines were done - The paint goes on almost before it goes out the factory door. That includes coolant hoses!!! |
81nautique
Here's a quesion for you guys with the older restored boats, referencing the very first set of pictures. Is it considered correct to detail the engine like that or just paint everything, nut, bolts, hose clamps, etc like the factory and some of the lower pictures. That first engine is beautiful but I'm sure not correct. At that point in the restoration is it a preference call by the owner? and does it hurt in judging a boat if it's detailed like that?
64X55
Gary - Yes that was the ticket. Look at these pics. You can tell now the color is good I think.
Pete - I sort of thought that was yours! Phatsat67 - Nice engine. What is it and what's it in? h2ol00 - Prepare for some "reverse" eye candy (i.e. my old 312 in my old Dunphy. Nothing pretty here (yet) see pics below)... See! Told You! Still pretty rough, but you can see the good match. The end of the portside exhaust manifold (near the exhaust hose) is the patch of new paint over the brighter (wrong) blue color. And then you can see the old oringinal paint for conparison on the head and here and there in the other two pics. I think the Alpine Green is a good choice even considering, what Pete said (somewhere above) about the faded with age factor. I'm fading with age a little myself! |
Inboards Rule!
reidp
This is the same color Phats is referring to above in a more true sense. But I believe it's still more blue than the original Interceptor green is supposed to be. This Chrysler "green" as they call it reminds me to a much lesser degree of the crazy Dupont Mystic paint, as it looks different in so many different lights as Phats noted. As for the Interceptor, I know there's some old shop somewhere that has to have a can of that stuff, which someone could match. Pete, hasn't it ever been an ACBS topic or challenge?
h20loo
Wow- there is some real eye candy in this thread. I'll have to do a search for more of Petes Dunphy.
70 Mustang project
Craig,
Yes, that's my 312. It's one in the batch of shots I sent to you for your reference. |
phatsat67
Chrysler big block green might work its close this picture makes it look a little more blue because of the color of the car under the hood. Just a thought.
I was going to say that you would be better off to paint a part to check match rather than matching to a plastic cap-
64X55
Is that your boat Pete? Wow, with only that amount of boat showing, it looks just like one I took of the Chris Sell Dunphy! Is it yours? I'm confused!
Hey, I can't post them cuz I don't have my cable with me, but I went ahead and sprayed just a little of the Alpine Green on a part of my 312 Interceptor that has been painted Ford blue (basically the valve covers and the exhaust manifolds) and took some pics. The heads and many other parts are actually the original color and it looks like "side by side" with where I sprayed, the Alpine Green is going to be a great match! I'll post the shots tomorrow. |
Inboards Rule!
