  New Posts New Posts RSS Feed - Takeing scratches out of gel coat
kilowake66 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kilowake66 Quote  Post ReplyReply Direct Link To This Post Topic: Takeing scratches out of gel coat
    Posted: February-27-2005 at 5:49pm
My 85 ski nautique has taken some scratches on the gel coat from an old dock that had screws sticking out. Is there an easy way to get the scratches out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morfoot Quote  Post ReplyReply Direct Link To This Post Posted: February-28-2005 at 9:55am
Wet sand the area with a fine sandpaper then increase the grit to at least 1000,1200 or more then buff. Be sure to keep the area wet at all times as you sand or you'll just make it worse. If the scratches are deep then you may need to do fill in the damage with a gel-coat repair kit. Just be sure to add the tint a little at a time to gfet as close to original as possible being sure to mix more than you need so that you can use it again in the future if need be.
WRoll View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WRoll Quote  Post ReplyReply Direct Link To This Post Posted: March-10-2005 at 6:14pm
Start with 1200 grit sandpaper then use 3m part number 6039 and 5928 polishing compounds. Also, order the correct buffing pads for the polishing compounds.
GottaSki View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2005 at 7:57pm
Yes, and preferably use a sander/grinder to buff, not those gai car buffers.
