new propellor |
saffer
Senior Member Joined: March-29-2008 Location: New Zealand Status: Offline Points: 113 |
Posted: January-22-2009 at 12:21am |
Hi guys (and girls)
Could you one the propellor masters please have a look on this NZ website and tell me what prop would be similar to a 542 ACME for my 88 SN 2001?? http://www.propellerservices.co.nz I would appreciate this as getting one from USA is out of the question much thanks |
lewy2001
That site is just importing the Austral Props from Australia.
Austral Props Australia I'm not sure but I think the taper on Aus/NZ prop shafts may be different to US shafts. If you have a genuine shaft you may have to get the prop machined to order. Check with Austral direct about the taper they will know. They do make a 13"x 12 and a 13" X 11.5 but how they match up to the Acme 3 blade props is unknown. Austral may be able to give you advice here also. |
saffer
thanks Lewy
I m following up, ironically it may be cheaper to get the Acme from US!! Keep you posted cheers |
Luchog
The Acme 542 is 13x11.5, wich because of it wide blades/cup design plus the CNC machining would make it a replacement for 13x12 non CNC propellers. It's also made of Nybral wich is Nickel/bronce(aluminium alloy
The thing is if these props you're looking at are CNC or not, I'd try getting the ACME. |
