  New Posts New Posts RSS Feed - Buying a shore station
crock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote crock Quote  Post ReplyReply Direct Link To This Post Topic: Buying a shore station
    Posted: April-07-2009 at 11:47am
I have a 1966 (or so) Skier with a Chrysler slant 6, original condition besides upholstery.
Anyone have a ballpark idea of how much the boat weighs for purposes of buying a shore station?
C
CRock
storm34 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote storm34 Quote  Post ReplyReply Direct Link To This Post Posted: April-07-2009 at 12:09pm
Crock,
      Sounds like I have the same boat, but mine is a bit of a project right now! If you look in the 1968 reference section it says that the Mustang weighs approximately 1600 lbs. I would guess that the Skier weighs a little less due to having a slant 6, but I could be wrong!
Edit: Lets see some pics of your boat....wel love pictures around here!
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: April-07-2009 at 12:42pm
Like Storm says, 1600lbs (dry) should be in the ballpark. Add some overhead for fluids, gear and people. Personally, I wouldnt consider anything less than a 3,000 lb lift.
WakeSlayer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WakeSlayer Quote  Post ReplyReply Direct Link To This Post Posted: April-07-2009 at 1:34pm
I have a 3000# Shorestation for our Mustang. 18ft. canopy. Perfect fit.
I am a big fan of Shorestations. I have one for my Super Air, and had one previously for my other two boats. The one thing I have always done differently with them is to get the Shoremaster guide ons. The Shorestation ones suck.
Mike N
1968 Mustang
RainDog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RainDog Quote  Post ReplyReply Direct Link To This Post Posted: April-07-2009 at 2:58pm
I put the Classic on a 3000# Shorestation that was previously used for our 17' Chris Craft Sportsman. Works great. The Classic tips in at 2500#
skierox View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skierox Quote  Post ReplyReply Direct Link To This Post Posted: April-07-2009 at 5:22pm
I agree with mike on the old foam white trailer guides on the shorestations. They really do not last and can cost as much as $20 per guide to replace. Reminder that the old metal are called 3698's which means 3,600 pound capacity and 98 inches wide between poles! The beam of your boat could be up to 98 inches! You can normally get a used steel with canopy for less than 1,000. They are solid, but very heavy!
Post Options Post Options   Thanks (0) Thanks(0)   Quote crock Quote  Post ReplyReply Direct Link To This Post Posted: April-07-2009 at 5:54pm
http://www.correctcraftfan.com/diaries/details.asp?ID=1354&sort=&pagenum=26&yrstart=1966&yrend=1972
Here is the post of the guy I brought it from - his title says 72 - but WI you did not originally need titles for the boat, and its fittings and body style indicate it is a 66-68 skier.
Reupholstered and runnning like a top.
C
CRock
Post Options Post Options   Thanks (0) Thanks(0)   Quote WakeSlayer Quote  Post ReplyReply Direct Link To This Post Posted: April-07-2009 at 6:11pm
The muskrats really enjoy them.
Mike N
1968 Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: April-07-2009 at 6:12pm
Based on the hull, deck and seats, Im pretty confident its a '69 or '70 Skier. If you can find the hull ID- either a plate attached to a stringer or the serial number on the plate next to the throttle- Correct Craft should be able to look it up and tell you for sure if youre curious. Cool boat!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-07-2009 at 7:06pm
   Reminder that the old metal are called 3698's They are solid, but very heavy!
Curtis, I have to disagree with Scott's recommendation here. Maybe it was all of the old steel Shorestations I had to struggle with (Scott is correct - they are heavy!!) way back in the late 60's early 70's at Watercraft Sales or loosing so many of the feet hauling them across the lakes with the work boat!! The biggest problem with the old steel ones is rust. I've seen them collapse because the most common point of failure is the tie rod ends that connect the front and rear cradle frames. We used to weld on new ends have them blasted and painted and 3 years later they would be in the same condition!
There are simply too many used aluminum ones out there that the steels (if you can still find one around) just aren't worth it. Nows the time - with the economy the way it is there are lots of lake homes on the market and lots of lifts not going into the water this summer!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote storm34 Quote  Post ReplyReply Direct Link To This Post Posted: April-07-2009 at 7:37pm
Crock...good looking boat! Looks like ours are very similar! Are you going to call correct craft and find out more info about your boat? I have been wanting to but never got around to it. How does your runs?
phatsat67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: April-07-2009 at 9:04pm
Yay a mopar sixer. Leaning tower of power:). Aside from that I have a 2600lb shore station for my 2001 and it holds it great. Its probably an early 90's model and it has only had one cable replacement. Its had various boats on it a 74 ski nautique an 87 SN and a few different pontoons. I dont use the guides but im just carefull. It has for hinged pads that conform to the hull.
canuck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote canuck Quote  Post ReplyReply Direct Link To This Post Posted: April-08-2009 at 11:02pm
I have an old 36110 steel shore station c/w canopy (I beleive it is 3600 lb capacity with a 110 inch width. I have used it for both a 1990 ski Nautique and my current 2002 196. I find it very heavy and in fact I floated it in close to shore last fall but left it in about 2 feet of ice this past winter. I'll soon know whether the ice damaged it.
Does anybody else find these shore station lifts a very heavy load to turn the wheel (by hand) to hoist the boat? Or is there something wrong with it?
CC Owner since 1989
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: April-09-2009 at 12:35am
It gets pretty heavy when you get it out of the water. Im a small guy and even my big friends are a little winded after lifting the nautique up enough to clear the prop and rudder of the water. Yours is all steel which probably adds considerable weight to the cradle. Mine is augerd into the ground under the water and it sits in ice every winter. Ofcourse, we are channel front so there isnt major ice movement like lake front. As long as you had the cradle outta the water id say your fine.
harddock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote harddock Quote  Post ReplyReply Direct Link To This Post Posted: April-09-2009 at 9:38am
Depending on if you need to and how much help you have putting in and taking out the boat lift you may want to look at Floe. The legs screw up & down to level with a socket on a battery drill and with a wheel kit it is almost a one man job. I would recommend at least a 3,000lbs lift. You may just bump up to an 80's or 90's boat someday.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-09-2009 at 11:09am
Originally posted by canuck canuck wrote:
I have an old 36110 steel shore station Does anybody else find these shore station lifts a very heavy load to turn the wheel (by hand) to hoist the boat? Or is there something wrong with it?
Check all your pivot points and the condition of your winch cable. Also as I mentioned previously, the rod ends on the tie rods connecting the front and rear cradle frames are a common wear point. One side always seems to wear more and this now binds the cradle as it's raised. Proper leveling so the complete frame isn't twisted is also key to it not binding.
Yes, they aren't the easiest to hand crank but age rust/wear will add to the problem! I electrified my Shoremaster years ago and that was still when I could crank it by hand!!
You should start looking for a used aluminum.
LaurelLakeSkier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LaurelLakeSkier Quote  Post ReplyReply Direct Link To This Post Posted: April-09-2009 at 12:42pm
Don't forget, your are lifting a lot of boat out of the water so it will involve some work. I look at it as the a work-out after my morning ski.
Once the boat is supported in "The Shore Station Fitness Center" I go for 30 cranks of the wheel before I take a break and coil my rope, give another 30, wipe down the boat and crank the final distance to tuck the boat up under the canopy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote canuck Quote  Post ReplyReply Direct Link To This Post Posted: April-09-2009 at 10:32pm
Hey 8122pbrainard you said you electrified your shore station - how does that work? Is there an electric winch? 12 volt or 110 volt?
Might be the answer for mine.
CC Owner since 1989
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: April-09-2009 at 10:42pm
I think its a rubber? wheel that mashes on the manual crank wheel and it just spins it that way. Ive saw a few around me lake. My arms wish I had the money haha.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-09-2009 at 10:55pm
I built mine using a 90 volt DC gearmotor. I'm about 150' from the house and was worried about the 120 volt voltage drop over that distance. Motors don't like it when they have to run on lower that 10% off the nominal. I've seen lawn sprinkling lake pumps burnt up because of low voltage. With the DC speed control down at the lift, if it puts out less than the max (90 volt) then the DC motor simply runs a little slower.
I didn't want to deal with battery charging if I used a 12 volt system nor did I feel solar charging was a option.
I kept my original winch and wheel just in case I needed to get the boat on or off during a power outage.
From the gearmotor I used a roller chain drive. The driven sprocket at the winch shaft is connected via quick disconnect "T" handle pins giving me the means of connecting or disconnecting the DC drive from the winch/wheel.
This whole project does require torque, HP and speed calculations with the gear ratio and sprocket drive ratio. If you can do this or find a friend with mechanical engineering skills, it's a great project.
The alternate is buying a commercially made electric drive from your lift manufacturer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote canuck Quote  Post ReplyReply Direct Link To This Post Posted: April-10-2009 at 12:25am
Thanks guys - great advice - sounds like 8122pbrainard is quite an inventive guy - my son is a mechanical engineer - so I will have to entice him into designing something like what you have. Similar to you, my boat lift is about 150' away from my lake house where the distribution panel is - so I probably have power loss as well.
CC Owner since 1989
Post Options Post Options   Thanks (0) Thanks(0)   Quote WakeSlayer Quote  Post ReplyReply Direct Link To This Post Posted: April-10-2009 at 1:12am
I have a Commander 12V motor on my Shorestation. I have it hooked to a solar panel and only have to give it one manual charge per season in about mid-August when the sun is headed south again. I have had great luck with this unit. I had one of the Shorestation units with the rubber wheel prior to this. It was decent but I still had the wheel on it, and I had to plug it into the boat whenever I wanted to lift it.
With respect to solar possibly not being adequate, my solar lift is on my 5000# lift for my SAN, which also has somewhere in the neighborhood of 1000 lbs of ballast left in it. It doesn't even struggle. It will not have any issue with a 2000 lbs boat. I manually crank up the Mustang to the top in one round of wearing out my arms.
Mike N
1968 Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-10-2009 at 10:30am
Mike,
In my case with the solar it was the amount of sun light the panel would get during the day. My shoreline is abrupt, steep (18 rises (steps) from the dock to the top) and is on the south side of the lake so this shades about half of the pier a good portion of the day. For aesthetics I didn't want to stick a panel way out from the shore. Also, I did this project 25 years ago so solar panels weren't as available and very pricey back then.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WakeSlayer Quote  Post ReplyReply Direct Link To This Post Posted: April-10-2009 at 1:39pm
That makes perfect sense. Hard to get sun on a north facing shore.
My cabin in No. Idaho is 5 miles off-grid. I am self sufficient with the exception of propane to heat water and run our fridge. I have a small, but pretty elaborate solar system there. I am a big proponent of that stuff. It is surprising how much power you can get from a little sun, even on a cloudy day, or in the dead of winter. In the summer I never have to use my backup generator, in the winter I need to run it for a couple hours every 3rd day or so.
Mike N
1968 Mustang
