Help!! |
Rusty2sb
Groupie Joined: December-11-2008 Location: Indiana Status: Offline Points: 45 |
Posted: May-08-2009 at 3:57pm |
looking for good pics of a dash for a 1980 SN. Am reinstalling guages and can't find my diagram I drew:( Have to remember which guage goes where? Also switch order would be helpful. Thanks!
Steve |
79nautique
left side I believe goes like this for the gauges temp, volt/amp, hourmeter, right side oil and fuel,
tachs in the middle speedos up top but those are the easy ones. switchs Nav, blower, bilge, horn was on the right I think where the hell's Tim when you need him. |
81nautique
Grand Poobah Joined: September-03-2005 Location: Big Rock, Il Status: Offline Points: 5778 |
a little help, I don't remember the order of the switches on the left but can look tonight if you don't have your answer by then |
79nautique
think you left a bracket or something out Allen
81nautique
All fixed, I left out half the url!!! |
BuffaloBFN
Damn sharp dash!!!
The Godfather
Platinum Member Joined: August-13-2008 Location: Orlando Fla Status: Offline Points: 1766 |
That boat look's fast just sitting there.
78nautique78
Groupie Joined: November-10-2007 Location: United States Status: Offline Points: 51 |
That looks like one of those mahogany shift knobs from Ski Dim like i've got...
Cheap beer, Trailer parks and Correct Craft. "Life is good".
Rusty2sb
Thanks guys for all the help, I got it. Only problem I am having now is on the left side. I am trying to figure out why there is an extra sender wire? I have a pink and a tan wire, the tan wire appears to be oil pressure, the pink wire is long enough to reach water temp or oil pressure? This is on the right if your cramped up under your dash:)
Thanks, Steve |
Steve,
Oil would be LT. blue and the temp would tan. |
Rusty2sb
On my boat the only blue is a lt blue and it is the loop for lighting the gauges? I just keyed on the boat and gauges light up, bilge, blower, and volt gauge all working. I left all the harness where they were so do to the old wiring, it pretty much is so stiff they all stayed in place where I unhooked them. My only options are pink and tan? |
Steve,
Take a look in the ref section. Not the same year but a couple of dash wiring diagrams that may help. The pink may be fuel and I think the tan is temp? Trace them back through the harness and see where they go. |
BuffaloBFN
My temp is tan and my oil sender is dk blue. I don't remember pink(though I should). We did just pulled it for a bath...will check back.
Rusty2sb
Appreciate all the help. I just need to take trip up to my uncles and climb under the dash of his 80'. One of those things:(
BuffaloBFN
Without pulling the back out of my boat, it looks like Pete has it on the pink wire...fuel sender.
Alan or anyone with the above pictured knob-could I get a top to bottom measurement, and the min and max diameter? I was told at the river that I have a very ugly knob! |
boat dr
[Alan or anyone with the above pictured knob-could I get a top to bottom measurement, and the min and max diameter? I was told at the river that I have a very ugly knob! [/QUOTE]
Is this going to turn into ; The Saga Of Polished Knob |
