  New Posts New Posts RSS Feed - WTB a reverse rotation SB Ford
ryangreta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryangreta Quote  Post ReplyReply Direct Link To This Post Topic: WTB a reverse rotation SB Ford
    Posted: October-07-2009 at 4:07pm
I own a 1967 Correct Craft Mustang. It had originally a 160 or 165 hp 289 ci 6 bolt bell housing engine. It lacked an intake and 2bbl carburetor. The 289 block is junk but I have the rest of the parts. I also have a 1974 302 with GT-40 heads built up but its standard rotation. I have a brand new Reverse rotation cam and lifters for a 302. I also have 2 types of Interceptor exhaust manifolds. Several flywheels as well.
What I want to arrive at is some kind of engine that's a Ford, runs backwards, heads designed for low end torque (I think), and is reliable and powerful. I am in the market for maybe a 289 block, a RH 302 crank, or E7E heads. Can you help? Advise is certainly welcome too!
Thanks,
Ryan
(419)260-0597
1996 Ski Nautique        1967 CC Mustang
Previously owned '69 Baracuda and '87 Ski
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: October-09-2009 at 2:12pm
Crankshaft is the same RH or LH
If you have the RH cam, all you need is a RH distributor, starter and crank seals.
AT
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryangreta Quote  Post ReplyReply Direct Link To This Post Posted: October-20-2009 at 3:23pm
Bump
Fl Inboards View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fl Inboards Quote  Post ReplyReply Direct Link To This Post Posted: October-20-2009 at 3:39pm
Where are you located?
I have a 302 Mercruiser about a late 70's edition.
It is pulled down, crank and block are together. rods and pistons went to the scrap heads are real old school. The motor came out of a 65 Nautique that Art at South East had, it was not the original motor.
Motor block is in good core condition It would make a good stroker set up.
