  New Posts New Posts RSS Feed - correct craft coupling
natural521 View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote natural521 Quote  Post ReplyReply Direct Link To This Post Topic: correct craft coupling
    Posted: April-28-2005 at 1:47pm
I have a 1987 ski nautique 2001. It leaks water between the hulls. I cant find out where it would posibly be comming from. I think that it is leaking around where the prop shaft goes through the hull but not around the prop shaft itself. also I canot remove the coupling on the prop shaft. the keyway is out and set screws are out and I have tried using a puller with no luck. I have tried everythig short of heating it, I do not want to damage the shaft or the coupling. can anyone help?
jameski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jameski Quote  Post ReplyReply Direct Link To This Post Posted: April-28-2005 at 2:59pm
The last time I pulled my coupling, it was very difficult, but I got it. The process I used took a while, but it worked. I found four bolts that were longer than the original coupling bolts and I put them thru the coupling and the trans flange with a small socket smashed in between the prop shaft and the trans shaft. Then I tightened the four bolts and it pushed the shaft out of the coupling. It didn't come out easily, but when I got the torque on all four bolts even, it moved. I was worried that I would warp my coupling or my flange, but I checked after I reinstalled my shaft, and they were not warped. Good Luck.
current boat
94 Sport Nautique
previous boat
78 Martinique
swamp demon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote swamp demon Quote  Post ReplyReply Direct Link To This Post Posted: April-28-2005 at 10:42pm
You might also check the rudder packing
JEFF KOSTIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JEFF KOSTIS Quote  Post ReplyReply Direct Link To This Post Posted: April-29-2005 at 1:19am
I checked my hull for leaks before with the boat on the trailer and filling the hull with water up past the shaft packing. I then saw where the leaks were under the dry boat. I found my water intake fitting was leaking bad. Dont put too much water in it where it might damage something!!!
