  New Posts New Posts RSS Feed - Fuel Shut-off valve ...
damonwells View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote damonwells Quote  Post ReplyReply Direct Link To This Post Topic: Fuel Shut-off valve ...
    Posted: October-19-2009 at 1:18am
A good idea ? Would think so, especially when changing fuel filters. 1990 SN FORD 351 PCM. I don't have one, 3/8 fuel supply line comes straight from tank to Inlet of Filter, then from Filter to Engine.
I would think best place to have one would be at the Inlet to Filter, no ?
A brass valve w/90 degree rotation is what I want ?
thanks, cheers, John
pink boat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pink boat Quote  Post ReplyReply Direct Link To This Post Posted: October-19-2009 at 1:40am
I have a 1994 merc. 350 and it has a valve as stated right on the filter (water separator). It has come in handy both in replacing the filter canister as well as changing out fuel lines. Just a simple 1/4 turn brass valve straight inline with the 3/8" line to filer housing.
Pink Boat
