  New Posts New Posts RSS Feed - Help me read my Multi Meter for Amperage
M3Fan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote M3Fan Quote  Post ReplyReply Direct Link To This Post Topic: Help me read my Multi Meter for Amperage
    Posted: December-15-2009 at 11:59am
Gang, I'm fairly handy with a multimeter but I've never measured DC current draw with it. The instruction manual is long gone and the tutorials online that I've found are generic, with every MM being a little different in one way or another. I'm trying to figure out how much of a parasitic draw I have on the car battery of my project/commuter car (1995 525i). I disconnected the negative cable from the battery and bridged it to the battery with my MM, with the settings below. The book says 100ma or less is acceptable, and with the settings below I get 00.05 on the readout. I believe that is 50ma, putting me in tolerance. Am I right?
2016 SN 200 OB 5.3L DI
https://forum.fifteenoff.com
C-Bass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote C-Bass Quote  Post ReplyReply Direct Link To This Post Posted: December-15-2009 at 12:22pm
I could be wrong, but shouldn't your red cable be plugged into the opposite side terminal to read DC mA, as evidenced by the green lettering on your dial selector corresponding to the green "mA" on the left terminal?
I'm sure one of the electrical guys will set me straight.
Craig
67 SN
73 SN
99 Sport
85SN
Post Options Post Options   Thanks (0) Thanks(0)   Quote M3Fan Quote  Post ReplyReply Direct Link To This Post Posted: December-15-2009 at 12:36pm
Yes, I believe the right hand side is 10A and the left is for ma. I noticed that after I did this. I think each side is just fused differently. That's probably why I'm getting 00.05 instead of 50.00 but I just want to make sure. I don't want to buy a new battery, then kill it with this car.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: December-15-2009 at 12:46pm
Joel,
Your cool and correct that the input is fused different. You'll notice the selector switch setting is correct for ether input as it has the red 20 ma. and the green 10A under it.
Sounds like you need a new battery but to be sure have it load tested. NOT at Autozone! They will tell you it's bad and need a new one no matter what shape it's in!!!
Have you checked to see if the alternator is putting out?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: December-15-2009 at 12:47pm
What is the rest of the lettering in the green DC section, the plugs are blocking something.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: December-15-2009 at 12:53pm
My guess is that is says mA.
Joel, sounds like youve got it all figured out. If you plug your red cable into the 10mA terminal and switch your setting on the dial to the 200mA range, you should get the most accurate reading.
Post Options Post Options   Thanks (0) Thanks(0)   Quote M3Fan Quote  Post ReplyReply Direct Link To This Post Posted: December-15-2009 at 12:55pm
Thanks Pete. HW, I think the black plug is hiding a green "10". Unfortunately Autozone carries the BEST cheap BMW battery ever, the Duralast 49DL so I'm going to have to make the trip, unfortch. The current battery is a AAA brand battery which is still under warranty (and probably also made by JC) but I believe the warranty is only for the original purchaser.
Post Options Post Options   Thanks (0) Thanks(0)   Quote M3Fan Quote  Post ReplyReply Direct Link To This Post Posted: December-15-2009 at 12:57pm
Also, here's a question for you EEs out there: Will the draw be the same regardless of battery state? e.g. if the battery is only putting out 10 volts will the car still demand the 50ma? I'm guessing yes because the car wants that amount of current no matter what. I did this same test with the battery charged and got the same result, but this last time I checked it I was down a couple volts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: December-15-2009 at 1:32pm
Yeah then switch the red lead (to mA), and set the dial to 200 you'll most likely see ~050.0 displayed.
Right now you are reading 20 A max, so .05/1000 = 50 mA
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: December-15-2009 at 1:50pm
The load is probably consuming (demanding) a certain amount of power (power = voltage x current). With a lower supply voltage, you should probably see a slighly increased load current in order to deliver the same amount of power. The difference in voltage we're talking about here (10v vs. 12v) isnt huge though- so depending on other factors (the settings and accuracy of the DMM, etc), you may not notice a huge difference in the readings.
FYI, this is the same principal that will cause starter solenoids to weld themselves shut. Try starting the boat with a bad battery (low voltage) and the starter will draw more current in order to draw the same amount of power... Too much current creates excessive heat and the solenoid contacts weld themselves together.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: December-15-2009 at 1:51pm
Tim stayed at a Holiday Inn last night.
Post Options Post Options   Thanks (0) Thanks(0)   Quote M3Fan Quote  Post ReplyReply Direct Link To This Post Posted: December-15-2009 at 2:14pm
This is a confusing aspect of electronics for me. How can a load (resistance) "draw" power? Isn't the battery the "engine" that is pushing electrons through the circuit? Thus how can something "pull" down the line? Why can mini xmas lights have such a small gauge wire (bonus question)?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: December-15-2009 at 3:27pm
Youre thinking about it backwards. The battery doesnt "push"; the load "pulls", if you will. While you can think of any load as an equivalent resistance in a circuit, you can also think of a load in terms of how much power it consumes (remember, power = voltage x current). A battery wont "push" power anywhere- if you dont attach it to anything it just sits there, its not trying to "expel" anything at a certain rate. It needs to have a load attached to it for current to flow- and how much current is dependant on what you hook up to it.
Bonus: Christmas lights generally consume about 25 watts of power for a typical 50 light strand. Plug them into 110VAC and that means each strand only draws 220mA. The selected wire size is dictated by the amount of current expected to flow through it... and it doesnt take a very big wire to handle 220mA. Check this chart (AWG vs. Max amps for chassis wiring) for a guide:
http://www.powerstream.com/Wire_Size.htm
Another example: This is the same principal that allows you to use a much smaller gauge wire to hook up an appliance if you run it on 220VAC instead of 110VAC. By using a larger supply voltage, you essentially cut the current flowing through the wire in half (the power consumption of the appliance remains constant).
tullfooter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tullfooter Quote  Post ReplyReply Direct Link To This Post Posted: December-15-2009 at 4:18pm
Like Tim said "(power = voltage x current)"
I like to put it this way; (Watts= Volts x Amps). So if you double your volts, 110v to 220v, you cut in half the needed amps for the same watts (and visa-versa). Using watts makes it easy to figure household usage, especially when sizing for generators.
The other easy way to think about current is with the word potential. The battery has the potential to send current from the positive side to the negative side. But without a circuit to do it, the load, it sits idle.
Oops, lunch is over. I've got some welding to do.
Play hard, life's not a trial run.
'85 BFN
'90 BFN
White Lake, Michigan
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: December-15-2009 at 4:40pm
... and electrical potential is voltage.
Post Options Post Options   Thanks (0) Thanks(0)   Quote M3Fan Quote  Post ReplyReply Direct Link To This Post Posted: December-15-2009 at 5:30pm
I still don't get it entirely. I guess my struggle is that I want to understand it at the lowest, most core level. That is how I like to learn anything- from the absolute ground zero and up. I don't want to understand it with equations, or just common "givens". I want to know exactly what is happening in that copper wire atomically and in the battery chemically to make it all happen. One day I'll blow a few hours on the Internet and catch up. As a side note I think society in general is really behind on fundamental science, chemistry, and physics knowledge, and that is too bad. I was ALWAYS into this stuff as a kid but electricity has always been a little mysterious at that core, fundamental level.
Post Options Post Options   Thanks (0) Thanks(0)   Quote M3Fan Quote  Post ReplyReply Direct Link To This Post Posted: December-15-2009 at 11:12pm
Put the new battery and took the same measurement- sure enough, current draw is lower. About 30ma. Go physics.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: December-16-2009 at 6:12pm
Tim,
You did stay at a Holiday Inn! Well said on the explanation.
