89 Ski Prop - Tim Need Advise |
Post Reply | Page 12> |
89Ski_Nautique
Senior Member Joined: May-26-2009 Location: Windermere, FL Status: Offline Points: 160 |
Posted: February-05-2010 at 6:32pm |
Tim,
Based on your experience which wheel would you recommend for an 1989 Ski Nautique that provides a good compromise between the best holeshot performance without sacrificing too much top end performance? 4 blades or 3 blade? We primarily use the boat for slalom skiing, no wake boarding. We operate with the standard gear and 2 adults 2 children no additional "fat sac" or additional ballast weight. Bill Weeks provided me with a few recommendations suggesting the Acme 1492-13.50X16.00VR4B 1.00 .105 cup four blade propeller and the ACME 422. We currently using what appears to be original Federal 14 x 16 RH. model: Ski Nautique boat_year: 1989 cid: 351 transmission gear_ratio: 1.23 rpm_high: 4450 - 4650 max_speed: 46-47 Thanks, Randy |
hunterdan
Newbie Joined: July-11-2008 Location: three rivers Mi Status: Offline Points: 34 |
I bought the Acme 470 3 blade for my 89.
Here is where I got it, the best price I found! http://marineelectronicsplaza.com/acmepropellers470125x15r1bore105cup3acmeinboardpropellers.aspx Dan |
Dan
mdvalant
Grand Poobah Joined: May-06-2009 Location: Bellevue, IA Status: Offline Points: 2059 |
Dan,
Was that 470 from the site you listed the real thing? I'm on the site now and it looks...shady...at best. lol Did you receive the prop already and use it? I want to do the same thing at a price like that but was a little leary... |
SNobsessed
Not Tim but that won't stop me from giving advice. I have both the 470 & 1442. Unless you are using over 1000 lbs. of ballast, I recommend the 1442 - the rpms will be a little lower & you will use less gas.
Some one has a prop in the parts for sale section that may work, but I don't have experience with that. I recommend Delta prop as the source. They are a site sponsor & give very good service. PS - If you join the Planet Nautique website, then you can get a discount at Delta. I don't know why they don't offer it to us. |
mdvalant
We do pull a lot of skiers on occassion....but I'm in the market for one that is an all-around good prop, hole shot, top end, can still pull some skiers off the dock (maximum of 12) we do it now with a 13X13 acme I believe but the RPMS on that get so high...
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21115 |
Chris is right on- Id go with the 1442. Youll see a few more RPM (100-200) than the stock prop, but you'll still be under 4800. I would expect you to gain a ton of holeshot and probably a little bit of topend.
Mdvalant, theres no such thing as a 13x13 Acme for a Correct Craft- they dont make that size in RH rotation. Either way, that size is way off for the 1.23 transmission in question. |
mdvalant
I wonder WTF size it is then...we got it in 04ish....would it be a 12.5X13? We had it recommended to us by ACME themselves so it must be correct...If it isn't, It sure has been working out great these last few years :) Pulled a record number 6 couples off the dock last season! :)
hunterdan
Hello, yes I was leary of that price also, and I did get the prop. Bill @ Acme knows me, and knows the company that is selling them, Bill says that they are selling them at ROCK BOTTOM prices ( near cost )
I am not going to guarantee you will not have any issues, but my transaction was very smooth, and yes I did confirm with Bill that it is a genuine ACME prop. I went with this over the 1442 because of the cost, and I think it was a great decision, it was a night and day difference from the stock one. Good luck! Dan |
Dan
89Ski_Nautique
Chris, Tim, Dan,
Great, Thanks for the advise, looks like I will go with 3 blades and the ACME 1442. I will post phots as soon as it is installed. Thanks Randy |
The Godfather
Platinum Member Joined: August-13-2008 Location: Orlando Fla Status: Offline Points: 1766 |
Randy, Getting the boat ready for St.Johns... |
89Ski_Nautique
Dave,
Dave, Everything was on track for us attend until yesterday... I received a call to be in Sterling Heights, MI from 17-26 February. You guys have fun and take lot of pictures. Maybe a chance for another reunion in the SE later this year. I miss the Sea World Reunions. Randy |
89Ski_Nautique
Tim, Chris
Thanks again for your advise, I opted for the ACME 1442, wow the surface area appears much larger when compared to the stock Federal propeller. See below. I highly recommend Delta Propellers; very courteous customer service and prompt delivery and they use very good shipping package. Great discount, be sure to specify the DP5CCF08 CCFAN discount when ordering. Stock Federal: New ACME 1442: Hopefully I can report back shortly the on the performance improvement. |
mdvalant
AWESOME! Thanks to this thread, I too purchased a 1442 from Delta. Great people, great price, great prop. Can't WAIT to try it out!
Randy,
Pull the Acme out of the box and take another picture of it and replace the picture you did post. It will give people a better idea of the surface area of the blades. When is it going in the water? I suggest you lap the new prop to the shaft. You joined in May of last year and I started this thread proper prop installation in February so don't know if you've seen it. |
SNobsessed
Randy - I can attest to Pete's advice on lapping. I foolishly ignored his advice & my prop came loose upon a hard reverse. Luckly the nut retained it on the shaft.
It only costs a few dollars & takes about 1/2 hour to do - well worth it. |
kapla
Pete you are right haha..when I first saw this picture I said..wait something is wrong there!! that props look like it came from the barber shop...its not even close to my 1442..then I noticed it was due to the package!!! |
<a href="">1992 ski nautique
Hollywood
Moderator Group Joined: February-04-2004 Location: Twin Lakes, WI Status: Offline Points: 13511 |
In the box, it looks comparable to the Federal, ha.
Hollywood
Federal 13x13 - ACME 540 13x12
89Ski_Nautique
Pete, Thanks for the lapping instructions,great detail....even I can follow these instructions! You are right I missed this earlier post. Stay tuned for an update with revised photos. I am unsure when I will get a water test I am hip deep in a technical proposal.
Randy |
lewy2001
Randy love the colour of your 89 have not seen many yellow ones. I have a ACME 422 on my 89 and it performs very well and is super smooth. Even with the boat heavily loaded it has no problems getting onto plane. The 1.23 tranny has a lot to do with this though.
Tim did a lot of testing on his 90 SN and concluded the 3 blades out performed the 4 blade ACME's. I like the idea of the extra diameter of the 1442. |
89Ski_Nautique
Just a quick update, I finally installed the new ACME 1442 this weekend.
The instructions supplied by Pete were so easy even I could follow them. Thanks, Pete. One small problem I had was removing the old propeller. The previous owner(s) did not use a stainless steel propeller shaft key, consequently the old Federal propeller was a real pain in the a** to remove. Just a friendly reminder make you use a stainless steel key since as you can see the photo above was badly rusted and took a lot of coaxing to get the key to slide out and remove the old propeller. I am now ready for a water test...... then I start wetsanding. Getting ready for spring. |
SNobsessed
Randy - You might want to bend that straight tail of the cotter pin toward the center.
At least that is what I do to prevent it from fatiguing. I sense a couple of different views on this coming . . . |
Chris, I'm with you on this one! |
89Ski_Nautique
Chris, Pete
Thanks for the tip, yes I bent the cotter pin around the center before I went to the lake. Gang, I went for test spin on Lake Butler today, this ACME 1442 prop rocks! Much better than the stock 14 x 16. The holeshot seems to be improved considerably and the top end is better than the old 14 x 16. Tim, Chris thanks for the advise, anyone who has not purchased one these for stock Ski w/1:23 transmission.....call today and place your order with Delta Propellers. Randy |
Good deal. Get us some WOT rpm's and a gps top speed number when you get a chance... Im curious how the 2001 hull compares!
89Ski_Nautique
Tim,
Will do as soon as I get back on the water...right now I am removing the hardware in preparation for wetsanding. Thanks, Randy |
89Ski_Nautique
Well better late than never in getting the WOT data. I finally have some WOT numbers to post for the ACME 1442 on our '89 Ski.
With the ACME 1442 on stock '89 Ski with points... WOT is now 4900 RPM which translated to 46.6 MPH average as measured using GPS equipment. The holeshot performance is significantly improved when compared to the stock Federal propeller...but I did not record any detailed timing / speed data. Incidently today the air temperature was in the low 80's, the humidity about 80%, with a slight NE breeze, on Lake Tibet at an altitude of 98 feet of above mean sea level. |
SNobsessed
Now that's what I call follow through.
Randy - you're quite the tease with that weather report! In the teens here in Iowa! |
eric lavine
Snob, if he owned a sled he would be wishing for some snow
lewy2001
I finally got to try a 470 on my 89 last weekend. With all the rain and flooding lately there is always debris in the rivers and dams and the 422 took a couple of small hits recently.
Decided it was time to try the spare prop in case I was forced to use it. I hade to fab up a new puller as the standard c clamp prop puller was not getting the job done. Lapped the prop as per "Pete's Proper Prop Installation" thread. I sure would be nice to sticky these really useful threads somewhere so they are easier to find. The 470 was up about 300rpm at boarding speed normally 22mph is 2400-2500rpm with the 422. With the 470 the rpm was 2700-2800rpm. At ski speeds it was worse 35mph 3800-3900rpm at 4600rpm we were only seeing 41-42mph. With the 422 I could not see 4600 rpm it would top out at 47.1mph gps at 4450-4500rpm. It would be a good prop on a heavily loaded 89 but I did not feel that the pull was any better than the 422 4 blade. I think the 1442 would be better suited to this hull the extra diameter would keep the rpm down. I think it may have even pulled higher rpm but it was time to pull up and the revs and speed were increasing ever so slowly. Fuel usage also increased with the extra rpms. I think adding a bit of extra cup would bring the rpm down not sure if it will be enough though. |
