changing V-drive oil, tranny fluid? |
jackkloepfer
Senior Member Joined: October-28-2008 Location: United States Status: Offline Points: 152 |
Posted: March-16-2010 at 9:46pm |
where do I access these two, and what oil and fluid is recommended for a GT-40, v-drive?
Thanks |
Jack,
Did you find anything in the reference section |
jackkloepfer
yes, I've looked the manual through. I'm just not seeing anything about the vdrive fluid.
WakeSlayer
V-drive fluid is 30W oil. There is a dipstick on the top. Use a suction gun to get the fluid out of that. Measure what you remove, and add that much. Check level. Run it, and check it again. You do the same for the trans with Dexron III. Without looking, I am positive that the manual shows both capacities.
Mike N
1968 Mustang |
jackkloepfer
thanks a ton.
kapla
pcm tranny I did the oil change last week..almost 2 quarts out...
<a href="">1992 ski nautique
Jack,
We'd like to know what happened with the freeze protection issue. Please don't leave us hanging!! |
kapla
yeah I ask about that in the other thread...but no answer yet....
Seb, Yes I did see you asked too. I asked in all of Jacks threads!! I sure hope we get a answer and Jack isn't one to ask and then run - never to be heard from again (or at least until his next problem!!!) |
79nautique
he e-mailed me and the oil looks good so far, he went ahead and changed the engine oil last night, he's a little worried 4 qts didn't drain, he still needs to let run some and get it hot to make sure a crack doesn't open up but so far so good. Suppose to be pretty good weather here for the next couple days so should be able to get some work done on it.
jackkloepfer
Sorry, guys. Yes, it does look like, for now, the major crisis has been overted. Sorry for the lack of update. I looked at the v drive compartment, under the middle rear seat, and I'm not sure HOW I'm supposed to get this dipstick out!?!? I looks like a blue knob, about the size of a quarter circumfrence, I am able to pull it upward, but I'm not sure how I'm supposed to get it past the rear backrest cushioning. Thanks for your continued assistance, guys! |
WakeSlayer
ummm, remove the backrest cushioning?
Mike N
1968 Mustang |
